problems removing snap ring / circlip / retaining ring
   / problems removing snap ring / circlip / retaining ring #1
boggen
Elite Member
Trivoli, IL
SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
allis chalmers 1954 CA tractor. a bearing went out going out to pulley that drives belly mower. end result = chewed up gears and lots of metal shavings.
i need to remove PTO shaft #5 from gear #37, main issue is #7 snap ring. ((see below link)) once i get these out of the way. i can get to belt pulley shaft, and tear it apart, find what all needs to be replaced.
Object moved
if above link does not work.. then....
Object moved ->
guest user (view books) button ->
type in "CA" and choose AGCO ALLIS from drop down menu ->
click CA link (bottom of search results) ->
DRIVE TRAIN - POWER TAKE OFF
#7 snap ring / retaining ring / circlip
it is an internal snap ring. (no holes for regular snap ring pliers *big frown*) one end = a 45 degree notch. i have not figured out anything that i can use to get in behind of the little edge. and pry out the snap ring from the grove. i have searched internet everything is for "with holes" not without holes. and if without holes, it = only installing not removing them *arghs*
i have used various screw drivers, metal filler end, that i grinded down with a little notching. but so far all the metal i have on hand. bends before i can barely get the snap ring to budge. (not enough to get anything behind it. to pry it out).
i am a bit un-easy drilling a "hole" into the main casting / pto body. near the snap so as to create a spot to pry the snap ring out. the snap ring holds the bearing in place. and any place i might get a drill bit into. is rather very ugly spot to drill into. and would be afraid of weakening things. to point of hooking up say a rotatory cutter or post hold digger, or other equipment. and run pto internal shaft right into the transmission.
i see comments in internet searching as a "one use only snap ring" assuming folks giving up and just grinding as much as possible of the snap ring out with a dremal. and buying a replacement snap ring.
going to need to find a "slide hammer" or something. to nock #5 PTO shaft. out of gear #37 (to get past the key in the PTO shaft). i had to replace the PTO shaft a few years back. due to cracking in half. and i had to use some rather hefty hits of a regular sledge hammer to nock everything together.
wonder if i can lift tractor up. and let it back down. onto pto shaft maybe. with extra bracing to push the shaft out *meh* sounds like i will be loosing a finger / hand. awell. :eek:
   / problems removing snap ring / circlip / retaining ring #2
I've had good "last chance" results with tools like these picks from harbor freight. If you break them, hey, they were two bucks!
4 Piece Pick and Hook Set
   / problems removing snap ring / circlip / retaining ring #3
I had a snap ring like that with no holes and 45 deg cut a few weeks ago. It was in a spot very difficult to reach. I was able to use these pliers to get the clip open enough to use a long skinny small flat screwdriver to pop it off.
Snap Ring Pliers with Interchangeable Heads
It did take several tries and some bad language, but I finally got it off. After you play with the pliers a bit, you will get the hang of opening the clip, trick for me was getting in the screwdriver in without letting it pop back in place. Maybe somebody will have a better plan.
   / problems removing snap ring / circlip / retaining ring #4
This is the tool to remove it.
   / problems removing snap ring / circlip / retaining ring #5
get a small tipped nail punch ( for driving finishing nails deeper) and a small set of "precision screw drivers" from the dollar store ..... grind 2 sides till it fits in the c clip groove , then grind the punch at a 45 degree angle across the tip ... now a very small sharp chisel ... set the sharp tip into the groove and the bevel side to the c clip and tap up against the C clip till it starts to pry it out of the groove ... slip a small flat screw driver between the c clip and the groove when you get enough free...
done ask'ed family. and mom showed up and dropped off below tonight. no clue were she found it locally. but looks like it might be the ticket! nice curve to it for prying like a regular claw hammer and looks to be correct thickness from initial glance. will try over weekend. *crossing fingers*
Amazon.com: Wilmar W1219 Seal Puller: Automotive
if above fails. i may end up going with your suggestion mossroad / jaotguy. and get a pick set. hopefully a harden set, that will not bend, vs other metal stuff i have tried so far.
   / problems removing snap ring / circlip / retaining ring #7
Here's some screen shots of the snap ring... hope that helps with suggestions. Part #7 is what the O.P. is looking to remove.
   / problems removing snap ring / circlip / retaining ring #8
It looks like you'd have to remove all that other stuff before it to get to that snap ring to open it to get it off the shaft?
   / problems removing snap ring / circlip / retaining ring #9
Boys that tool I posted it works eather flat when you have all kinds of room or up and down when there is no room. I don't think that seal puller is going to get it. Hope it does.
leejohn
a pair of angled needle nose pliers, no go. there is nothing to pry on per say.
mossroad.
shim between bearing cup and snap ring. covers end of PTO shaft, just enough. to make hammering the shaft out rather difficult.
allis chalmers ca pto shaft snap ring.png large exploded diagram. once you click image you may need to click it once or twice to see large picture.
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
KARCHER PRESSURE WASHER (A51244)
KARCHER PRESSURE...
(INOP) 2015 JOHN DEERE 744K II LOADER (A51242)
(INOP) 2015 JOHN...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2018 ATLAS COPCO V4 PORTABLE S/A LIGHT TOWER (A51243)
2018 ATLAS COPCO...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
