boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,829
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
allis chalmers 1954 CA tractor. a bearing went out going out to pulley that drives belly mower. end result = chewed up gears and lots of metal shavings.
i need to remove PTO shaft #5 from gear #37, main issue is #7 snap ring. ((see below link)) once i get these out of the way. i can get to belt pulley shaft, and tear it apart, find what all needs to be replaced.
Object moved
if above link does not work.. then....
Object moved ->
guest user (view books) button ->
type in "CA" and choose AGCO ALLIS from drop down menu ->
click CA link (bottom of search results) ->
DRIVE TRAIN - POWER TAKE OFF
#7 snap ring / retaining ring / circlip
it is an internal snap ring. (no holes for regular snap ring pliers *big frown*) one end = a 45 degree notch. i have not figured out anything that i can use to get in behind of the little edge. and pry out the snap ring from the grove. i have searched internet everything is for "with holes" not without holes. and if without holes, it = only installing not removing them *arghs*
i have used various screw drivers, metal filler end, that i grinded down with a little notching. but so far all the metal i have on hand. bends before i can barely get the snap ring to budge. (not enough to get anything behind it. to pry it out).
i am a bit un-easy drilling a "hole" into the main casting / pto body. near the snap so as to create a spot to pry the snap ring out. the snap ring holds the bearing in place. and any place i might get a drill bit into. is rather very ugly spot to drill into. and would be afraid of weakening things. to point of hooking up say a rotatory cutter or post hold digger, or other equipment. and run pto internal shaft right into the transmission.
i see comments in internet searching as a "one use only snap ring" assuming folks giving up and just grinding as much as possible of the snap ring out with a dremal. and buying a replacement snap ring.
going to need to find a "slide hammer" or something. to nock #5 PTO shaft. out of gear #37 (to get past the key in the PTO shaft). i had to replace the PTO shaft a few years back. due to cracking in half. and i had to use some rather hefty hits of a regular sledge hammer to nock everything together.
wonder if i can lift tractor up. and let it back down. onto pto shaft maybe. with extra bracing to push the shaft out *meh* sounds like i will be loosing a finger / hand. awell.
Object moved
Object moved ->
