My Septic System Experiment
   / My Septic System Experiment #1
Pettrix
High Desert Southwest
I installed a fine air tube diffuser inside my first chamber in my 2-chamber septic system and ran air to the diffuser 24/7 for the past 6 months. It costs me about $3.00 per month in electricity. It's a new system on a new home.
Here are the results after 1/2 a year of use:
A - The septic tank has NO smell once you open the tank lid. It actually has an "earthy" smell, kind of like soil when wet.
B - There are NO solids in the tank. It's just liquids.
C - The effluent filter in chamber #2, before it heads to the leach field, was very clean. No debris on it, just some slime bacteria.
This proves to me that aerobic systems are way better than anaerobic systems. Studies I read show 10x faster digestion and breakdown of wastes and the effluent is much cleaner as it heads into the leach field. This also helps with the biomat in the leach field. One is less likely to have a failure in the biomat with an aerobic system. In addition, I might never have to pump the tank since the solids (poop & toilet paper) are breaking down so quickly.
My last home had an anaerobic system that smelled really bad when accessed and required pumping every 5 or so years. The methane gas produced by anaerobic breakdown is very caustic to the concrete septic tank. Since the aerobic system has basically no methane gas, the longevity of the concrete tank is indefinite.
I'm now a believer in aerobic septic systems. The entire setup cost me $300 in parts and labor was free (me). :laughing:
   / My Septic System Experiment #2
Sounds like good **** to me.
   / My Septic System Experiment #3
Care to elaborate on the design of your system, I've got 2 3-chamber systems that I'd like to modify, one has a air injection currently but it eats motors every couple years, and at about $300 each time, that gets pricey! That system uses a motor to spin a hollow tube with a T shaped end that acts as a venturi to suck air down the tube into the chamber. I'm thinking it uses more electricity than your system, as it runs about 50% duty cycle.
   / My Septic System Experiment #4
Could you share the specific parts you used for your system? I致e been hoping to do something similar to our system.
   / My Septic System Experiment #5
I appreciate the info. It’s an interesting concept that has been around for some time now. This would be good for folks with undersized tanks and or too many chemicals going into the tank.
Am I the only one laughing when OP said his **** don’t stink? Instead of an earthy smell I have more of a lavender aroma.
   / My Septic System Experiment #6
I've thought it is similar to fountains and aerating ponds... maybe different but my city has spent a fortune on a municipal "Lake" and it turned the tide...
My tank is a 2-chamber 2,500 GAL concrete tank (it will eventually serve 2 homes). The leach field consists of the Infiltrator chamber systems. My system is a 100% gravity fed conventional system.
Your system sounds like an "engineered" system that has air injection and grinder pumps. You must be in an area that the soil did not perc good.
I run a Hakko 40L air pump with a 3/4" PVC pipe that then feeds air to a Matala EPDR rubber air diffuser. The diffuser then sits in the 1st chamber of the tank. It's pretty much the same setup they use in ponds to aerate the water.
I run a Hakko 40L air pump ($180) with a 3/4" PVC pipe that then feeds air to a Matala EPDM rubber air diffuser ($60). The diffuser then sits in the 1st chamber of the tank. It's pretty much the same setup they use in ponds to aerate the water. The other $60 was spent on PVC piping and some rubber weighted air hose. The air pump sits inside the garage so it is protected from the elements. I ran the PVC pipe next to the 4" sewer pipe from the home. That way it is buried and out of sight/protected.
   / My Septic System Experiment #9
I'm signing in as I'd like to follow this. My septic would be very easy to set up like this.
Yep, the system setup is designed for ponds but it works great in a septic system. Same concept, same formula, of using oxygen to create an aerobic water system which helps break down waste and keep the water cleaner.
According to Wiki:
...aerobic process for digestion rather than just the anaerobic process used in septic systems. These systems are commonly found in rural areas where public sewers are not available, and may be used for a single residence or for a small group of homes. Unlike the traditional septic system, the aerobic treatment system produces a high quality secondary effluent, which can be sterilized and used for surface irrigation. This allows much greater flexibility in the placement of the leach field, as well as cutting the required size of the leach field by as much as half.
A typical ATS will, when operating correctly, produce an effluent with less than 30 mg/liter BOD5, 25 mg/L TSS, and 10,000 cfu/mL fecal coliform bacteria. This is clean enough that it cannot support a biomat or "slime" layer like a septic tank. ATS effluent is relatively odorless; a properly operating system will produce effluent that smells musty, but not like sewage. Aerobic treatment is so effective at reducing odors, that it is the preferred method for reducing odor from manure produced by farms.
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
1268 (A50490)
1268 (A50490)
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
