1 year old tractor won't start after idle winter
   / 1 year old tractor won't start after idle winter #11
To me, the obvious things are battery (already mentioned) and the battery cables. Remove the cables from the battery, solenoid, starter and ground. Remove the battery, check the electrolyte levels - top as needed. Charge it with a 2 amp charger overnight. It should be 12.8v - 13.4v at that time. If not replace. Closely inspect the cables for creeping green death (copper corrosion). Replace if you find any. Clean the metal on each area down to shiny metal - coat with dielectric grease. Replace the battery, cables and it should start.
jb
   / 1 year old tractor won't start after idle winter #12
diesels draw a lot more current than a gas engine at start up. If your battery is dead jumper cables won't do it. You will need to charge the battery, change the battery or use a good jumper box. I always get a dead battery so i know from experience jumper cables don't cut it. You just get rrat rrat sometimes if the battery not that low i can get rrrat rrat rrat vroom.
Thanks everyone for your timely responses. I had figured if it wouldn't jump that we had a bigger problem. Fortunately, a new battery is annoying but straightforward and I will be able to do that tomorrow and finally get to work. I really appreciate the help.
   / 1 year old tractor won't start after idle winter #14
art said:
I'd test the battery as they should last longer then a year. You might find the problem on the starter end of the wires.
That starter end is one thing that could cause you problem too. Before you buy a battery check teh terminals at the starter.
murph
   / 1 year old tractor won't start after idle winter #15
I would be checking a couple of other thing's before I changed the battery. If you tried to jump it and it still didn't start the battery may be fine. Check ALL starting system wiring connections. You may have a loose or corroded terminal elsewhere like the starter solenoid etc... Just trying to prevent you from buying a new battery and still having the same problem.
Checked the connections back to the starter; all looked clean and firm.
   / 1 year old tractor won't start after idle winter #17
Pull tractor battery, put battery off of one of your other vehicles on it and see if it will start. Can you short across starter solenoid and get it to start (with battery that is suspect). You say connections "looked" clean and firm. Did you take them loose, clean, and tighten as has been suggested?
What kind of tractor is it?
   / 1 year old tractor won't start after idle winter #18
Are you doing all of this work without ever testing the voltage in your battery? Is the engine frozen?
   / 1 year old tractor won't start after idle winter #19
this is kind of simple to test...just do what i posted before and what btdt said. just use a different known good battery and see if it starts.
the battery in my tractor is history but i can get it going with a charger after a while. stupid thing doesnt really need a battery cept to start.
   / 1 year old tractor won't start after idle winter #20
The tractor out here if you let it sit more than a couple of days, when you go to crank it, it will turn over for a second and stop then you just hear the solinoid buzzing. At this point you have to walk to the front, take off the nose / headlight assymbly to get to the battery. In my case, it is the frame's ground connection that gets corroded just enough. Sometimes instead of undoing the connection, you can take the 3/4" wrench and give it a few hard whacks (its just a ring terminal attached to a bolt in the frame) and climb back in the cab and it will crank right up. The battery? It is brand new only 3 months on it.
When it is like this hooking up jumper cables doesn't help since it isn't the battery, it is the connection to the starter. At first I was scratching my head. You would think a diesel with 2 750cca batteries and a 120A alternator would have enough oomph to jumpstart a tractor engine with slightly less displacement.
2025 Leopard F50 X-pro Mini Dirt Bike (A56859)
2025 Leopard F50...
2018 Vermeer BC700XL Woodchipper (A57453)
2018 Vermeer...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2016 Chevrolet Traverse SUV (A56859)
2016 Chevrolet...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
