Loader 1025r loader arms not working together
   / 1025r loader arms not working together #1
Chrisbinnc
John Deere 1025r
Hi all! Been a couple of years since I posted on here. Hope y’all are doing well.
I’ve noticed on my 2018 1025r that when I switch attachments on my loader arms, one seems dead or dragging compared to the other one. It was slight at first but now it is making putting an attachment on a bit annoying.
Anyone else have this experience? Suggestions on how to fix this?
Thanks,
Chris
Sent from my iPhone using Tapatalk
   / 1025r loader arms not working together #2
One side has air instead of fluid in the cylinder. Easy fix. Run the loader down and hold it in bypass and it will expel the trapped air.
   / 1025r loader arms not working together #3
Chris
Do you notice any difference in how one side lifts vs other? If one side is always lagging or lifting less I would suspect bad seals on that cylinder.
Air in a cylinder makes them bounce or spongy. Sometimes will also cause them them to have jerky movements vs smooth
   / 1025r loader arms not working together #4
Just sounds like a timing bar/tube on QA issue to me. (tube between you loaders QA plates bent or moving)
   / 1025r loader arms not working together #5
I own a 2025r which is similar to yours. When I take the bucket off and put it it back on the hook up is usually a little out of whack. One side is usually a little more forward. I just drive up to the bucket or forks at a slight angle to make up for it.
   / 1025r loader arms not working together #6
Thanks,
Chris
Not clear on your problem. What John Deere attachment system do you have?
Is it this style?
   / 1025r loader arms not working together #7
DK35vince hit the nail on the head, I think. The shear pin has broken and needs to be replaced.
   / 1025r loader arms not working together #8
Exactly.
If the cross tube/timing bar has a shear pin that's the first thing I would check.
   / 1025r loader arms not working together #9
I had the same issue with a JD 5400. Just a little bolt to fix.
   / 1025r loader arms not working together #10
First I've ever heard of that. Wonder, why did they use a shear pin in the torque tube? May be an excellent idea, just never heard of it before. I guess if you had a failure of some kind and it caused twist on the torque tube it would simply shear a pin rather than twist the tube??
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
