12 Guage Slug Range /Ballistics ?
   / 12 Guage Slug Range /Ballistics ? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Is it possible for me to hit my neighbors house?
The deer tend to come out into a clearing, that when I see them, they are usually at is at an elevation higher than my vantage point (i.e. it would be an uphill shot). A definite no-no with high powered rifles. But what about a 12 gauge slug?
Looking at the picture, the worst case scenario would be shooting from down in a gully (at the right end of the red line shown) at deer 100'-150' away, uphill, still in the clearing. The house (at the left end of the red line) is about 1300' away (horizontally) and 160' (vertically) above me.
If I aimed too high, and was shooting at (say) a 45 degree angle upward (worst case?), could the slug land 1300' away at an elevation 160' above me?
I know the correct answer is don't chance it, shot from a different position, etc.. but....is it physically possible?
   / 12 Guage Slug Range /Ballistics ? #2
From the internet, Winchester says max range for a slug is 1068 yards, way more than the distance to that house.
   / 12 Guage Slug Range /Ballistics ? #3
The ballistics of a "rifled slug" is way to vague to give an accurate answer. You will need to know the ammo and it's characteristics before one could know for sure.
Most of these calculations are done in yards/meters and not feet. 1300' or a little over 400 yards is a bit close. However, hunting in the southern part of Illinois (or other large dry land farming regions) shotguns are required because of the proximity to structures and people.
The link below is one of the "worst cases" with regards to a slug. In other words it tends to shoot farther and flatter than most other options. Note the projectile has lost over 1/2 of its energy and dropped over 9" by 200 yards.
With regards to what is safe- consider your loved on is standing at your neighbor's house. Any decision to fire should be done with that frame of mind.
https://www.hornady.com/ammunition/shotgun/12-ga-sst-300-gr-ftx-slug
I've never studied "buck shot" but that may be an option for a 50 yard shot. Again, I don't know those ballistics though.
Buck shot is probably much safer, except for the deer, but maybe not legal.
   / 12 Guage Slug Range /Ballistics ? #5
If you get serious about this your other option is a nice black powder rig. You could work up a load that would only be lethal to 80 yards or so. I'm not sure you can do that with shotgun slug- I've never tried to reload shotgun rounds
Is there a good website or app that shows trajectory for a 1 oz (440 grain) projectile that is shot at 1800 fps at 45 degrees (worst case). Or do I have to dig out the Physics books?
   / 12 Guage Slug Range /Ballistics ? #7
Coby, if there are ANY doubts at all, no way would I take that shot. Many deer are not worth any chance of an accident. No. Don't shoot.
   / 12 Guage Slug Range /Ballistics ? #8
Bing Bing Bing! MacLawn has the right answer. If you have to wonder if this is a good idea, then it is NOT. Too many things can go wrong here.
Later,
Dan
   / 12 Guage Slug Range /Ballistics ? #9
Winchester Sabot slug shot up at 45 degrees.
SSP12- 12Ga. 385 gr. @ 1900 fps: 2,971 Yards
Allow at least 200-300 yards more for downwind shots.
   / 12 Guage Slug Range /Ballistics ? #10
You need the ballistic coefficient of the projectile to figure it- then their are lots of free online calculators.
   / 12 Guage Slug Range /Ballistics ? #11
What HE needs is to be SAFE and NOT shoot in THAT direction!!
SR
   / 12 Guage Slug Range /Ballistics ? #12
What's the cost of being wrong?
Maybe a dead neighbor? A child? Mother?
Why would even consider doing such an irresponsible thing?
   / 12 Guage Slug Range /Ballistics ? #13
Never shoot unless you know exactly what is in line of thr shot. It may not hit your neighbors house a 1/4 mile away, but what about a hunter that is out there?
I have turned down many "skyline" shots not knowing who or what was over the hill.
Close to 30 years ago I had a driver that was hit in the arm with a rifle shot from the neighbors shooting a sheet of plywood on a rise with no backstop.
Gary
   / 12 Guage Slug Range /Ballistics ? #14
Wow! I'd love to see the calculator that generated this. 3000 yards (9000 feet) makes dang near 2 miles. That means my 300wm must go about 10 miles. Again, wow!
   / 12 Guage Slug Range /Ballistics ? #15
A heavy slow bullet will travel farther than a light fast bullet. Speed is temporary, mass is permanent. The high speed light weight bullet sheds it velocity at a higher rate than a slow moving heavy bullet. That shotgun slug will easily travel the 400 yards to your neighbor's house. And it will still be quite lethal when it gets there.
For the sake of everyone around you, do not do this.
Also, don't think of it as "just because it's a shotgun", think of it as, I can shoot a lead projectile 3 times the weight of a "deer rifle" bullet, over my horizon. And a black powder rifle is just as deadly, so don't think, "oh, it's a muzzle loader, it must be ok".
"What about a hunter that is out there?" The same could probably be said for 75% of shots not fired from a tree stand.
Rest assured:
1) I have no plans of to take a "skyline" line.
2) Even if someone did, the slug would have to negotiate several hundred feet of trees and branches before it went above the tree line.
3) I haven't deer hunted in about 25 years, and don't have any serious intentions to sit around doing so in the near future. I'm more of a cold blooded killer, I like to raise my food by hand, give it a name, pet it often, and develop a personal relationship with it before I kill it and eat it. (i.e. more of a farmer than a hunter). :rolleyes:
I was more curious of the theoretical ballistics.
   / 12 Guage Slug Range /Ballistics ? #17
snag from the "net", so only hear say.............
"..may be longer than you think:
I received a direct answer on the estimated maximum danger range of rifled slug, sabot slug, .44 magnum and 45-70 rounds from Winchester Ammunition:
X12RS15- Rifled Slug, 1 ounce @ 1600 fps: 1,068 Yards
X44MHSP2- .44 Mag. 240 gr. @ 1760 fps: 2,239 Yards
X4570H- .45-70 300 gr. @ 1880 fps: 2,291 Yards
The Winchester Tech. recommended adding 200 to 300 additional yards to allow for velocity variations, temperature, wind conditions, etc."
A long ways!
   / 12 Guage Slug Range /Ballistics ? #18
Copper sabot slugs from a rifles shotgun barrel hit hard and shoot fairly flat out to 125-150 yards
   / 12 Guage Slug Range /Ballistics ? #19
Rest assured:
The ballistics of the shot would be fun to figure. I asked for the calculations that generated the 9000' projectile distance as I haven't seen a calculator that calcs that far.
For your given scenario I would used a BC of .20. Here is a fun calculator-
Ballistic Calculators - Hornady Manufacturing, Inc
   / 12 Guage Slug Range /Ballistics ? #20
Rest assured:
Been following and you made me try to find the answer. I used to hunt with the "pumpkin ball" in areas restricted to that and always figured a slug fired from ground level would be "in the dirt" at about 300 yards and even then it wouldn't pack much punch (still a lot because it is 1 oz. of lead). That was before rifled barrels and 3" sabot type slugs...I have to say that I was amazed at the differences in drop and energy...probably explains why Wisconsin now allows rifles just about everywhere since it doesn't seem to matter and the rifle may be a little more accurate. But to your point, I didn't find a comprehensive ballistics calculator either.
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2016 FREIGHTLINER...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
