1968 ford 3500 no pto
   / 1968 ford 3500 no pto #1
bksanti
Chino valley az
1968 ford 3500
Hi I'm new this forum but I'll give it a shot. I have a 1968 ford 3500 industrial tractor. Has a 3 point hitch but no pto. How would I run a mower or other attachment. Could I add a pto? Thanks Ben.
   / 1968 ford 3500 no pto #2
Not practical to add a PTO, you'd have to change out from transmission Back. You could add Hydraulic drive motors but that can get costly.
We're would I tie the hyd controls into.
Can I put a out put shaft in the spot in the rear of the tractor.
Thanks Ben
   / 1968 ford 3500 no pto #4
Thanks Ben
That's a pretty old tractor and parts may not be readily available...and if a PTO wasn't an option when the machine was new...well, adding a PTO drive is not feasible. Nothing is impossible, but I'm sure it would cost more then the tractor is worth.
   / 1968 ford 3500 no pto #5
I bought an entire rear end (PTO, 3 point, brake to brake) for converting mine.. Paid $600.
Thank you. I think ill use a hyd motor with controls. Just don't know where to tied them into the tractor hyd system. Thanks Ben
   / 1968 ford 3500 no pto #9
You would supply the pto valve first from the loader pump. Then, PB from the pto valve to the loader valve. IIRC, the pump should be somewhere around 17gpm for the loader. You could probably get everything you need from surplus center.
2022 Ford F-150 Pickup Truck (A59230)
2022 Ford F-150...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2020 CATERPILLAR 320 GC EXCAVATOR (A60429)
2020 CATERPILLAR...
Adams 16T Tender Body (A61307)
Adams 16T Tender...
1459 (A57192)
1459 (A57192)
