1972 ford 4000 3 cylinder diesel cav pump problem
   / 1972 ford 4000 3 cylinder diesel cav pump problem
Yep .... leak off lines up on injectors are leaking now and need to be replaced i guess it just sat too long ,,,,,thank you for all your help i learned alot and you were an amazing wealth of info. for this first time new member thanks again ...
   / 1972 ford 4000 3 cylinder diesel cav pump problem #43
Leak off lines are leaking....the theresenough pressure at injectors....must start when cranking
i took the top off again and the banjo nut where the leak off line goes cause there was no fuel returning and cleaned the fitting out started cranking to bleed the injectors still no air or fuel at the injectors
anything else you might think of before i replace pump ????
   / 1972 ford 4000 3 cylinder diesel cav pump problem #47
rebuild is cheaper than replace, in 90% of cases.. just sayin..
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
