1972 ford 4000 3 cylinder diesel cav pump problem
   / 1972 ford 4000 3 cylinder diesel cav pump problem
does not look like the fuel is returning to the tank do you know if there is a check valve somewhere in the system ???
   / 1972 ford 4000 3 cylinder diesel cav pump problem #12
Is there a window on the side with a fuelline mounted to it ? That banjobolt do have a valve in it to pressurise the sisteme a little
i was looking at that....thats where the injector lines go on the pump....i was afraid of that also seems like no fuel is returning to tank
yes it runs down from the fuel filter i took off to make it easier to get the top off put it back on no leaks
   / 1972 ford 4000 3 cylinder diesel cav pump problem #15
Your next test wil be to see if the injpump is rotating !
could you tell me how to do that ??? loosen the bolts at the pump where the timing marks are ???
   / 1972 ford 4000 3 cylinder diesel cav pump problem #17
No! At the other end of the pump with the fuelhose on it...remove the hose ...then remove the backend of the pump...leeve the vanes in ...keep it in with your finger and crank the engine an see if the vanes is rotating....the strip that part and clean the filter in that part
Ok thank you I will give it a try today thank you for your help ...my first go at all this thank you again
Thank you that would help i have some manual's but they don't go into that much detail on the pump
WB Mower (A50120)
WB Mower (A50120)
Genie Scissor Lift (A53421)
Genie Scissor Lift...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
1978 Taylor TY-250M Forklift (A53117)
1978 Taylor...
