everything was in tact on the pump side put my finger on there and had my helper crank the motor and everything spinning good my pump has a filter in the housing where the fuel line hooks in filter fine hooked the fuel line to the housing fuel poured out ...put everything back together .....disconnected injector line at the pump cranked the motor fuel is oozing out slowly but not squirting out ????? you think i should check the metering valve again ????
