1972 ford 4000 3 cylinder diesel cav pump problem
   / 1972 ford 4000 3 cylinder diesel cav pump problem
Yep .... leak off lines up on injectors are leaking now and need to be replaced i guess it just sat too long ,,,,,thank you for all your help i learned alot and you were an amazing wealth of info. for this first time new member thanks again ...
   / 1972 ford 4000 3 cylinder diesel cav pump problem #43
Leak off lines are leaking....the theresenough pressure at injectors....must start when cranking
i took the top off again and the banjo nut where the leak off line goes cause there was no fuel returning and cleaned the fitting out started cranking to bleed the injectors still no air or fuel at the injectors
anything else you might think of before i replace pump ????
   / 1972 ford 4000 3 cylinder diesel cav pump problem #47
rebuild is cheaper than replace, in 90% of cases.. just sayin..
1997 National RV Tropi-Cal T/A 35FT Class A Motorhome (A51694)
1997 National RV...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2016 Wells Cargo Enclosed Trailer (A53117)
2016 Wells Cargo...
2018 Genie GTH-5519 (A50123)
2018 Genie...
