OP
breedtractor
Do you have to stop and use the clutch to shift between forward and reverse?
No worries about a bucket as rusty as that one? Or the chips on the loader arm, cause maybe he/she knocked it against something?
I doubt that’s spent 24 years on the sun. It looks pretty good plus it’s got newish tires and a seat.
Photo #1 shows three pairs of rear hydraulic ports. This would be unusual on a residential use tractor. Ports may indicate commercial use.
So, yes. Owners of commercially operated tractors are motivated to reduce labor cost of employee operation.
I have one pair of rear hydraulic ports on my owner-operated tractor. Two pairs not too unusual. I speculate 15% of compact tractors have either one or two pairs of rear remotes.
Three pairs of rear remotes very unusual outside of commercial operation.
The guy said they had a landscaper package installed, allowing for implements to be rotated without getting out and manually adjusting. He also said that was in and of itself a $2500 package.
Photo #1 shows three pairs of rear hydraulic ports. This would be unusual on a residential use tractor. Ports may indicate commercial use. I do not like tractors used commercially. You have the issues of "Get 'er done regardless" and an ever changing cast of semi-experienced operators, with only the owner having a vested interest in maintaining the tractor. Owner-operated (only) tractor prefered.
My garage stored, owner-operated L3560 has 1,750 engine hours and looks much, much better than photo tractor.
The FEL and bucket look worse than the rest of the tractor. Maybe it was used to move road salt, bulk fertilizer, concrete constituents, dairy manure or some other material corrosive enough to eat through the paint.
I speculate tires and wheels are replacements due to moving corrosive material. Seat is not OEM Kubota.
VIDEO: How To Evaluate A Used Tractor - YouTube (L3800)
1. It is your money. You have to decide.
2. Is tractor close enough so you can inspect it and test it?
3. You can make a cash offer of less than $11,500 AFTER INSPECTION.
Have you considered a NEW, open station, Rural King by TYM RK37 model at $22,000 + sales tax?
Tractors | RK37 Series Tractor | RK Tractors
