1996 Kubota L3600 - Good Deal or Watch Out?
   / 1996 Kubota L3600 - Good Deal or Watch Out? #1
breedtractor
Member
KY
JD 4300
I've got an opportunity to get a 1996 Kubota L3600 with a box grader, bush hog and finish mower for $11,500. From the pics, it looks like it sits outside but seems to be in decent condition. I'll see it in person next week, but any thoughts about the price and or things to be leery of? Just looking at the only comp on tractor house, it's 1G more, but come with the implements...
Thanks in advance!
   / 1996 Kubota L3600 - Good Deal or Watch Out? #2
A 24 year old tractor that sits outside wouldn’t be something I’d want unless it’s a real bargain which it doesn’t sound like.
   / 1996 Kubota L3600 - Good Deal or Watch Out? #3
Good, basic, mainstream tractor. Outside stored the big caution is rodents chewing the wiring. Lesser caution contaminated fluids, water small problem, algae big problem. Weathered tires, hydraulic lines and other rubber components to be expected. Tractor tires generally need replacement at 1,700 to 2,000 engine hours.
Does L3600 have a Front End Loader? Is it 2-WD or 4-WD? What transmission does it have? How many engine hours?
L4400 is enough tractor for 10 - 20 cleared acres.
Potentially a much, much better tractor than the gray market Yanmar.
FOR YOUR INFORMATION:
Kubota L3600
1994 - 1999 Grand L Series
Compact Utility tractor
Previous model: Kubota L3650
Next model: Kubota L3710
Series next: Kubota L4200
Series back: Kubota L3300
Kubota L3600 Power:
Engine (gross): 38.5 hp [28.7 kW]
Engine (net): 35.7 hp [26.6 kW]
PTO (claimed): 31 hp [23.1 kW]
Plows: 2 (14-inch)
Kubota L3600 Tires:
Standard tires (ag): Front: 6.00-16. Rear: 13.6-24 (2WD)
Front: 8.3-16. Rear: 13.6-24 (4WD)
Dimensions:
2WD ROPS Weight: 2,800 lbs [1270 kg]
4WD ROPS Weight: 2,955 lbs [1340 kg]
Drawbar capacity: 1,430 lbs [648 kg]
2WD Wheelbase: 71.3 inches [181 cm]
4WD Wheelbase: 71.1 inches [180 cm]
Length: 118.1 inches [299 cm]
Width: 56.1 inches [142 cm]
Height (steering wheel): 60 inches [152 cm]
Height (ROPS): 83.5 inches [212 cm]
Ground clearance: 13.2 inches [33 cm]
Front tread: 45.1/49/53/56.9 inches (2WD)
[114/124/134/144 cm]45.5 inches [115 cm] (4WD)
Rear tread: 42.5/46.4/47.2/51.2/57.1/60.8 inches
[107/117/119/130/145/154 cm]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post ROPS.
Transmission 1 : FST
Type: synchronized shuttle
Gears: 8 forward and reverse
Clutch: dry disc
Oil capacity: 41.2 qts [39.0 L]
Four gears (1-4) in two ranges (low/high) with left-hand shuttle lever. Gear shifts (1-4) are synchronized using the foot clutch. Shuttle shifting is also synchronized using the clutch. The tractor must be stopped, and clutch used, to shift ranges.
Transmission 2 : Glide Shift (GST)
Type: power shuttle
Clutch: dry disc
Eight-speed gear shift (1-8) with left-hand shuttle lever. Power shuttle shifting without need for the clutch. The transmission can be shifted (without the clutch) by sequentially shifting up through the gears.
Hydraulics:
Type: open center
Capacity: 10.3 gal [39.0 L]
Pressure: 2490 psi [171.7 bar]
Pump flow: 7.8 gpm [29.5 lpm]
Page information:
Last update: January 21, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: Peter@TractorData.com
GST 4wd 1300 hours with a front loader, and all of the implements previously mentioned. Algae? Where would that be, in the lines?
   / 1996 Kubota L3600 - Good Deal or Watch Out? #5
Algae could be anywhere there is fluid.
With only the information available, which is not that much without an inspection or a lot of photos, I consider this package a good deal at $11,500. OUTSIDE STORAGE IS A CAUTION.
With its age and outside storage tractor will likely require four new tires very soon. You can research tractor tires prices on eBay. Probably $1,500 for a set of four new tractor tires, plus installation.
   / 1996 Kubota L3600 - Good Deal or Watch Out? #6
4570: How do you value your Kubota L3800 without implements ?
   / 1996 Kubota L3600 - Good Deal or Watch Out? #7
I sold my 1998 Kubota L2900 (500 hours) with several implements for about $14k. I did a complete 500 hour service on it and I replaced all of the hydraulic hoses in prior years. It sat outside for the last 12 years but she polished up really nicely. Good tractor.
   / 1996 Kubota L3600 - Good Deal or Watch Out? #8
Garage kept, 250 hours, HST. About $18,000. But there’s quite a bit of difference in the 2 machines. After 24 years outside the paint is junk, the tires are junk, the hoses are junk, the seat is junk, and possible water contamination in the fluid.
So these are the pics I was given. I assumed due to the rusty bucket and rust under the seat that maybe it had been stored outside. Also, look at the back of the seat...maybe I'm nit-picking? What do you guys think?
6003683144685349885.jpg6038496739410417627.jpg5293277365294911804.jpg1829968805630533620.jpg-5767525478852493230.jpg-2015622070262919444.jpg
   / 1996 Kubota L3600 - Good Deal or Watch Out? #10
I doubt that’s spent 24 years on the sun. It looks pretty good plus it’s got newish tires and a seat. Has it got the better glide shift transmission or the lesser grade 1-4-high/low that requires clutching every time. I could live with a glide shift but the lesser one is terrible.
Coleman Go Cart (A51573)
Coleman Go Cart...
200 Gallons of Detergent (A51573)
200 Gallons of...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
HAMM HD+ 120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120I...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
