2-4-D for Dandelion Control?
   / 2-4-D for Dandelion Control? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
My neighbor sprayed his whole lawn (2.75 acres) with 2-4-D today to control dandelion weeds. The bottle says broadleaf weed killer. I know this product has been around a long time. Any predictions as to what this will do to his lawn? He's never used this stuff before and a guy at the hardware store told him to do it. He diluted 1 gallon into about 30 gallons of water.
Jerry
   / 2-4-D for Dandelion Control? #2
Mrwurm,
You needed to mention to your neighbor that he needs to spray everyone elses lawns also!! /w3tcompact/icons/shocked.gif
Funny thing about Dandelions - they kinda spread their seed on their own. They have a knack for this. /w3tcompact/icons/eyes.gif/w3tcompact/icons/wink.gif
<A target="_blank" HREF=http://www.24d.org/>2-4-D Website</A>
You may want to share this with your neighbor....
Terry
   / 2-4-D for Dandelion Control? #3
2-4-D is made to spray on grass. It will leave the grass unharmed and kill the weeds.
   / 2-4-D for Dandelion Control? #4
I just did a further seach and used the proper term "2,4-D" and came up with a hit that just made me cringe.... Agent Orange - yes, the stuff used in Vietnam. Agent Orange was a 50/50 mix of 2,4-D and 2,4,5-T (sounds ominous to me!!).
Not trying to sound like a tree-hugging environmentalist or an alarmist, but I try to limit the use of any pesticide or herbicide.
The wholesale use of chemicals to make a yard look "pretty" makes no sense to me.... especially if you live in a rural area. /w3tcompact/icons/eyes.gif Oh well - to each his own.
Terry
   / 2-4-D for Dandelion Control? #5
2,4-D is not all as bad as the Agent Orange makes it sound. Probably the majority of the beef that people eat has been on pastures sprayed with 2,4-D. It is a very common broadleaf herbicide, and has not been linked to any serious medical conditions in humans as far as I know. Probably the best site for information on this herbicide is <A target="_blank" HREF=http://www.24d.org>http://www.24d.org</A>. You can find just about anything you are looking for about 2,4 on this site. I understand your concerns, and I prefer to go with a natural solution over a chemical one myself, but until we come up with a more natural way to control weeds which is cost effective, 2,4-D is likely here to stay.
   / 2-4-D for Dandelion Control? #6
Terry,
It turns out that the problem with the agent orange was dioxin, which is very toxic.
This chenical was a byproduct of the production process used to create the 2,4-D (2,4-dichlorophenoxyacetic acid) and 2,4,5-trichlorophenoxyacetic acid (2,4,5-T) mix.
Modern 2,4-D contains no dioxin and is a result is pretty harmless.
If you have ever used weed & feed or similar you have used 2,4-D.
Fred
   / 2-4-D for Dandelion Control? #7
I use it all the time,knocks the snot out of Dandelion,Buckhorn and any Broadleaf including Cover.
But,the "drift" of 2-4-D is very tough on garden plants and flowers.A use product called Triamec around the house and shrubs.It's a bit higher in cost but does'nt have the odor of 2-4-D.
Also I put on 1-1/2 qts. with 50 gallons of water per acre.A gallon to 30 gal. sounds pretty stiff to me,but it would depend on the % rate of the chemical itself.
Thanks to all that responded, some good information was dispersed.
Jerry
   / 2-4-D for Dandelion Control? #9
Thanks all for the additional information.
Again, I'm no environmentalist or alarmist. However, I try to stay away from using any chemicals. Now for the caveat.... unless we MUST to control noxious weeds. In the 10 or so years that we've had our market garden, we may have used two gallons of pre-mixed Roundup. We would rather cultivate prior to the weeds setting seed. Of course, we have less than an acre to worry about so that makes it somewhat more manageable.
Now to change the subject and concentrate on a little problem I'm trying to correct. /w3tcompact/icons/wink.gif
There is only one weed that has eluded our attempts to manage. It is Bind weed. What is the BEST way to get rid of it. The problem with this weed is that it's roots spread quickly. If you till the area and break the roots into smaller pieces you end up with many more plants.
Any ideas??
Terry
   / 2-4-D for Dandelion Control? #10
I have heard that Cashmere Goats will eat most broadleaf weeds down to a point where they cannot survive, and then the grasses (in a pasture at least) crowd them out. If this is in a garden, I suppose the goats might not work out so good though...
Massey Ferguson 9250 (A56438)
Massey Ferguson...
24in pin on excavator tooth bucket (A56438)
24in pin on...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
