2.7 ecoboost opinions
   / 2.7 ecoboost opinions #51
I believe the ecoboost engines require premium fuel when towing....check the manual.
No.
However Ford states higher octane ratings can be used to unspecified advantage when the engine is being worked hard. Ford says you can use premium, the engine will adapt to premium, but they won't lay it on the line and say what benefit.
Many who tow, race, and/or have dyno'ed the engine say HP output improves with higher octane ratings. So perhaps there is more HP but there is no need or requirement.
   / 2.7 ecoboost opinions #52
There is a way to adjust the computer to be more accurate on your mpg. I read about it on an F150 Forum.
Yes, and the beauty of it is that the owner can push buttons on the console and make the correction without any special factory tools.
   / 2.7 ecoboost opinions #53
There is also the issue of duty cycle. If you look at a semi, it is expected to operating at heavy loads most of the time. Although the 1/2 ton trucks have great capability, most will not be towing heavy a large portion of the time. I think if you told Ford you expected to be towing 10K constantly, they would tell you to get a 250/350 diesel instead of a 150 Ecoboost.
The 2.7EB is perhaps the strongest overbuilt truck-like engine we have seen in decades.
   / 2.7 ecoboost opinions #54
Here ya go:
Take your hand calculated MPG and divide it by the computer display MPG....then multiply by 1000. This new number is what you will change the AFE Bias to.
Example: 18.3/19.6 = .9337xxxx. Multiply by 1000 = 934 (rounded up) as the number to use.
For Lariat and up 8 inch meter Display:
Engine off.
1. Press and hold OK Button on the left side of the steering wheel and don't release it until the end.
2. Press push start Button only (Not Brake Pedal) to turn to Accessory Mode.
3. Once Message*accessory Mode appears.... press the Brake Pedal and turn the Engine on.
4. Engineering Test Mode appears instantly. Release OK button.
5. Scroll to AFE Bias and push OK to change it to the number you calculated. Note, it takes quite a few clicks to get to AFE Bias.
6. Once done, turn off truck and it will update your mpg, including your Trip 1 and Trip 2. You'll see it has changed the next time you start the truck.
Note....quite a few of us have been successful just holding down the OK button, starting the truck, then releasing the OK button once Engineering Mode pops up.
For 4.2 inch meter Display:
Engine off.
Press and hold OK Button on the left side of the steering Wheel.
Continue holding OK button and start the engine...don't let go of OK button until "Engineering Test Mode" appears.
Go through the menu pressing and releasing OK Button until you reach "AFE Bias 1000" appears.
Press and release Down. Using Left and Right change 1000 to the Number You calculated. Press OK.
To leave Engineering Mode after you are done, just turn the engine off.
   / 2.7 ecoboost opinions #55
No.
Car and Driver magazine recently tested several different vehicles to check the effect running premium versus regular would have on them. It made no appreciable difference to any of the vehicles - except the Ford Ecoboost. Premium gasoline netted better fuel economy and better power.
Is Premium Gas Worth It? We Test High Octane on 4 Popular Vehicles
   / 2.7 ecoboost opinions #56
The article refers to the "high output ecoboost" which is the 3.5L used in the Raptor version of the F-150 (450hp, I think). I wonder if the conclusions apply to the "regular" 3.5L and 2.7L ecoboost versions too.
   / 2.7 ecoboost opinions #57
They did not test the Raptor, they tested the Limited edition. Although it still has some awesome power ratings for such a small engine...That torque rating is better than my 5.9 Cummins!
   / 2.7 ecoboost opinions #58
I believe that is the reason Ford is coming out with the 7.3 gas engine in the super duty line. Fleet box trucks, etc work harder hour after hour and (I think) Ford thinks the higher displacement will help.
   / 2.7 ecoboost opinions #59
Trust me, with a performance tune & 93 octane, a 2.7 F150 is a different animal. :D
I wondered about this. I also wonder how the rest of the drivetrain would hold up to more power 🤷*♂️
2006 New Holland LS180 (A55272)
2006 New Holland...
KOMATSU WA270 (A58214)
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
2006 Dodge Ram 1500 Pickup Truck (A56858)
2006 Dodge Ram...
