AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,419
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
Where in the Dakota's ?? My wife has folks in Sioux fall SD .. I read that record numbers of replacement heifers are being held back .. Future will tell the story. Hay prices simply confuse me ... When there is none they sore to extreme highs ... Then this yr as wet as this given area is an ample supply for those that have been able to get into the field it's cheap .. I saw an ad the other day on CL ... 4x6 net wrapped Bermuda with 500 lbs to the acre of fertilize good clean hay that was sprayed $30 a roll ... Give me a break if anyone really believes that you can spray and apply FIVE HUNDRED # to the acre and then sell for 30 bucks .. I may be way off base .. Just doesn't figure out for me .. I may need someone to explain that too me.
Cousin's are cow/calf operators in the Iona, SD area (north of Gregory and south of Reliance). My Dad lives in Reliance. I'd be all over that $30 round bale... if it wasn't a CL scam! Might be one of those deals that "if it sounds too good to be true - it likely ain't true"! Sure don't appear to pencil-out very well...
AKfish
