220 volt 30 air compressor 10 CFM
   / 220 volt 30 air compressor 10 CFM #31
ultra, I wasn't worried about you... directed toward Gregster.
I wasn't sure how the garage shop was wired so one of the first things I did was map the circuits... it is nice it is all in emt conduit.
   / 220 volt 30 air compressor 10 CFM #32
If it is all in conduit can't you change a circuit over to 220v? Seems like it would be easy.
   / 220 volt 30 air compressor 10 CFM #33
My brother has had this unit for about 1 1/2 yrs... Campbell Hausfeld Portable Electric Air Compressor Model# VT6271 dictcg
have been using this same 220v model for several yrs now. mounted wheels on front, so it's very easily rolled around. 11 cfm max. very pleased, ideal shop model, handles all my impact wrench, etc needs perfectly. & far more mobile than upright tank styles.
for portable construction site air tool needs, lots to choose from, but as mentioned, you'll sacrifice output
   / 220 volt 30 air compressor 10 CFM #34
   / 220 volt 30 air compressor 10 CFM #35
20 gallon 13.7CFM and it is portable
   / 220 volt 30 air compressor 10 CFM #36
California Air Tools compressors are very low CFM units.
Suitable for small pneumatic tools only.
They also have 4 hp 220v units spec'd at 12.80 CFM @ 40 PSI and 10.60 CFM @ 90 PSI but looks like the 220v offerings don't have wheels.
   / 220 volt 30 air compressor 10 CFM #37
Do you really have a lot of 220v plugs around to be able to move a 220v air compressor? I don't. I install 220v plugs where I need them. And my 220v plugs are different. Some run my welder 50 amp. Some run my air compressor 20 amp. Some run my table saw 30 amp.
If you are going to use extension cords wouldn't it be easier to add more air hose than electric cord?
   / 220 volt 30 air compressor 10 CFM #38
cheaper to buy battery tools than run air hose and a big compressor - but if needed run hose not move compressor around
   / 220 volt 30 air compressor 10 CFM #39
Ultrarunner, Thanks for the clearer picture. Just air-line the tanks together and that will equal to more air power? or just a larger supply of air? Still don't see how that provides any more line pressure, rather just a longer time before unit kicks on to charge back up.
Dragon, I have quite a few available receptacles but yes they are on the same circuit. I believe that two 110v units would still function but I haven't yet tried it. I will be cautious and aware of the possible tripping of breaker hazard. Thanks for pointing that out.
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A57024)
2019 RAM 5500...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
