ctc111 - like I said, you can rule out carbon monoxide (CO) 100% simply due to two facts:
1.) Diesels do not produce enough to worry about.
2.) If they did you would not be here thinking about it.
If you ever do actually suspect that you or anyone else has been poisoned by carbon monoxide from any spark ignition engine, the
LAST thing you want to do is go purchase a carbon monoxide meter to find out how much you are being poisioned.
The is analagous to playing Russian Roulette and after firing a bullet into your temple you check to see if there is any empty shell case in the chamber... /forums/images/graemlins/shocked.gif
The
FIRST thing to do in ANY suspected carbon monoxide poisoning from any spark igintion engine is to stop whatever is going on and go see a medical doctor within the next 5 seconds, a simple blood test for hemoglobin and the physical color of your blood is all it takes to get you on an oxygen respirator and a blood transfusion. CO is lethal in <15 minutes
Remember, compression ignition diesel engines do not produce enough carbon monoxide to worry about despite what anyone else says. /forums/images/graemlins/wink.gif
http://www.cdc.gov/mmwr/preview/mmwrhtml/00050544.htm
NOTICE: During the follow-up investigation, environmental CO sampling was performed. With the tractor stationary and its engine running, a monitor was placed where someone working on the setter would sit; CO levels of an average of 477 parts per million (ppm) were detected during a 15-minute sampling period. ** Four other gasoline-powered tractors with comparable exhaust configurations, manufactured between 1947 and 1979 (the tractor used while the woman was working was manufactured in 1967), were similarly tested. Fifteen-minute CO levels were 38, 364, 507, and 706 ppm.
"Tests conducted on a diesel-powered tractor resulted in zero ppm CO for the 15-minute testing period." /forums/images/graemlins/wink.gif
Finally, CO sampling performed using the woman's equipment and simulating planting procedures detected levels of 384 ppm in 15 minutes. /forums/images/graemlins/frown.gif
