2210 carbon monoxcide posining with cab
   / 2210 carbon monoxcide posining with cab #31
Rubber mats for tool boxes would work. Or if you have any old car floor mats you can cut to fit. Tool box mats should be available at TSC, Sears, Lowes etc.
   / 2210 carbon monoxcide posining with cab #32
"As I stated before, diesels do not produce enough CO to worry about, but they extrude loads of NOx and that my friend is caustic, poisonious, noxious, and did I say poisonous if it is absorbed by your lung tissue and gets into your bloodstream."
As I said before, I wouldn't worry about what it is, just eliminate it it.
   / 2210 carbon monoxcide posining with cab #33
</font><font color="blue" class="small">( "As I said before, I wouldn't worry about what it is, just eliminate it it. )</font>
In the immortalized words of Davros as told to the Daleks -> ELIMINATE
but why two "its"? /forums/images/graemlins/wink.gif
   / 2210 carbon monoxcide posining with cab #34
I'm not quite sure how you would eliminate any problem when you have not actually determined why the man is getting sick.
If I have a problem I like to test first to determine the correct remedy to eliminate the problem.
Is it NOX, carbon monoxide, adhesives used in the construction of the cab, or is the member just ill?
Putting a cure in place before finding the cause seems to me like putting the cart in front of the horse in my opinion.
   / 2210 carbon monoxcide posining with cab #35
seems a RV dealer/suppliers should be able to get you a 12 volt detector.
   / 2210 carbon monoxcide posining with cab #36
Sporty's Pilot Shop
Here you go. No batteries, or batteries or 12v lighter plug. I don't think CO is the problem though. See above technical reasons. If it was you would have had the problem this winter.
when i got really sick i did not have both doors off i just had the small windows but i was thinking that the fumes were comming in the front window
i threw the doors on today and turned it on and drove around the yard for about 15 minutes and i started to get a headache. (maybe it was just me getting worryed about getting sick again) But i was driving it yesterday with the doors off and i was fine so its something to do with the fumes.
And i think SkyPup is really onto something on what it is. He seems to really know his stuff
   / 2210 carbon monoxcide posining with cab #40
Here is a link to some good information on Diesel emissions. It also has exposure limits to the different constituents listed. CO, NO, NO2 and SO2 are all hazardous to your health.
Diesel Exhaust
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
Brushfox HD-78 (A53421)
Brushfox HD-78...
More info coming soon! (A50323)
More info coming...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
