2310 diff-lock broke again
   / 2310 diff-lock broke again #11
I stop, apply gentle pressure to the lock lever, gently apply hydro pressure and it drops in as soon as one wheel starts to spin. I have a little over 400 hours with much severe, 4 wheelin' type use, no issues with the diff lock.
That is the way it should be engaged.
   / 2310 diff-lock broke again #12
On big row crop tractors they seem to have a much better setup. You can use them all the time and seem not to have any issues. On utility tractors and smaller I know allot of guys wont use them because they seem prone to breaking. Im not saying you cant use them but often over time they just don't hold up well. All the small tractors have in common the mechanical activated type and I think that is where the problem starts because ever operator is a little different on how they use them. On the big tractors you simple push a switch or a button on the floor.
u got about 30 hrs or so left till she blows. dealer says u can only go straight in diff lock and pedal should engage sitting still, maybe the 2410 has a better lock, 2310 not strong enough. I only drive on dirt. major project.
I called the factory and they blew me off to the local dealer and the mf ers at MF said its me, no one has ever called about this before, they have never had to work on one, use the diff lock only in a straight line, never make a turn, never drive any more than a few feet at a time in diff lock, don't even look at the diff pedal or you will be sorry! it took all day to take apart, 1000 parts. It must cost a lot at the dealer
   / 2310 diff-lock broke again #14
ronnierhino, you're lucky you can do that repair; I'm not sure I'd even attempt it! I'll bet you've saved a ton of $$.
My 2310 is just coming up on 500 hrs, and I bet I've not used the diff lock more than a half dozen times since I've had it --just to get myself unstuck-- but never had any trouble with it, other than having to "tickle it" to get it to drop in, using the same method others have posted. OTOH, my tractor has had very little time in the woods.
Sorry you've had trouble with it, but it does sound like maybe you're asking more than these little tractors can deliver. I always figured the diff lock was only for emergencies.
Thanks for the great pics, however! Always enjoy any time I can look inside the thing to see what makes it tick. ijk
   / 2310 diff-lock broke again #15
I have a 2004 gc2310tlb and the locking rear diff has broken again, the pins on the locking ring have sheared off for the 2nd time and it takes all 3 parts to fix, $500 last time, anybody else have this problem or knows what causes this? I might weld up the 3 parts and have a locked rear all the time I'm all ways in the dirt.
I have a tractor massey ferguson GC2610TLB 2009
And I had the same problem as yours, the cost of the repair was $ 1500 parts and maneuvers without taxes.:furieux::furieux::furieux:
   / 2310 diff-lock broke again #16
I even had this problem on my tractor GC2610 2009 parts cost me $1600, and the work in all $ 2400
:furieux::furieux::furieux::furieux::furieux::furieux:
me have 900 hours
   / 2310 diff-lock broke again #17
me have 900 hours
My little 1531 massey ferguson tractor has a locking rear end feature. I have used the daylights out of it. I only engage it when back wheels are stopped. I never engage it whole the tractor is in motion or back wheels are spinning. So far I have had good luck with my locking rear end feature. I did see a Kubota with the locking rear end torn out about 25 years ago. I have been stuck quite a few times. If you have a loader on your tractor, a lot of time you can push yourself out backward with the front loader. Somtimes I give up and get a bigger tractor to pull it out. Please let me know how tough it is and what challenge you faced tearing into the rear end. My pto has shell again. Dealer cbarged 5500 dollars to rbuild it last time. Trying decide if I can do it myself.
me have 900 hours
me have 900 hours
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
