2320 - How do i stop this leak
   / 2320 - How do i stop this leak #31
Stuff a rag in there so the oil doesn't drip on the floor, and change the "diaper" once in a while. ;) :)
UPDATE - Well i picked up a set of universal joint sockets yesterday and played with it a little this afternoon.. It is such close space even the 1/4" universal was too long.. I can get a socket on the nut there there is NO room behind it to get a rachet on it.. :-(
I also tried a wrench on it.. You cant even get the socket end on the nut, but you can get the open end on it BUT you can swing the wrench <1.5" at a time if i got it loosened up..
So it appears that unless I take a lot of other parts off I will just have to live with my leak.. I am taking some time off tomorrow, so I will keep playing around and see if i can figure out a fix..
thanks for all the help
b
   / 2320 - How do i stop this leak #33
Rather than a rubber washer, I would use a copper washer commonly used where brake hoses bolt to brake calipers with a banjo bolt. An Auto Parts store should be able to match to the size you need.
Good luck with the repair. Looks challenging.
Zebrafive - I was at AutoZone and saw those copper washers and wondered if they would work
BUT - I messed with the bolt again this morning and due to the limited access to the area, I just buttoned the tractor back up and will just live with the leak until it gets worse..
Somehow I ended up with 2 bolts from the dash area left over.. oops.. I do know they are from that area because I kept them together..
thanks for all the help.. I really appreciate the brain trust TBN offers..
Brian
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
Mini Plate (A57149)
Mini Plate (A57149)
2124 (A58376)
2124 (A58376)
