2320 - How do i stop this leak
   / 2320 - How do i stop this leak #31
Stuff a rag in there so the oil doesn't drip on the floor, and change the "diaper" once in a while. ;) :)
UPDATE - Well i picked up a set of universal joint sockets yesterday and played with it a little this afternoon.. It is such close space even the 1/4" universal was too long.. I can get a socket on the nut there there is NO room behind it to get a rachet on it.. :-(
I also tried a wrench on it.. You cant even get the socket end on the nut, but you can get the open end on it BUT you can swing the wrench <1.5" at a time if i got it loosened up..
So it appears that unless I take a lot of other parts off I will just have to live with my leak.. I am taking some time off tomorrow, so I will keep playing around and see if i can figure out a fix..
thanks for all the help
b
   / 2320 - How do i stop this leak #33
Rather than a rubber washer, I would use a copper washer commonly used where brake hoses bolt to brake calipers with a banjo bolt. An Auto Parts store should be able to match to the size you need.
Good luck with the repair. Looks challenging.
Zebrafive - I was at AutoZone and saw those copper washers and wondered if they would work
BUT - I messed with the bolt again this morning and due to the limited access to the area, I just buttoned the tractor back up and will just live with the leak until it gets worse..
Somehow I ended up with 2 bolts from the dash area left over.. oops.. I do know they are from that area because I kept them together..
thanks for all the help.. I really appreciate the brain trust TBN offers..
Brian
2134 (A58376)
2134 (A58376)
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
Ford F-250 Bed (A57453)
Ford F-250 Bed...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
Pair of 10' Fork Extensions (A57149)
Pair of 10' Fork...
