beersngars
Had a Carters and liked it. Switched to a Speeco Quick Hitch and love it. :thumbsup: The Carters is just laying on my work bench and I may part with it. Shoot me a PM if interested.
get a 3 to 5 lb hammer....makes a big difference sometimes....keep it in your tool box.
Ok, did my first change out today of attachments (Box Blade to 3 Pt Receiver Hitch). Just a quick briefing I am new to SCUT'S and 3point attachments! Ok is it really as much as a pain as I just experienced? I figured you pull the pins drive off attach the next. Seems like you have to twist turn and maneuver your attachment to get weight off of the pins. Am I missing any tricks? Should I be running out for this iMatch system? Doing all kinds of stuff around the house. I want to be able to be box scraping, be done with that, throw the 3 point receiver hitch on to trailer stuff around the property, quickly switch over to a heavy ballast to start moving boulders.
Just not looking to break down a schedule on when I am doing what because that attachments aren't as easy to get off as I thought. And I could see myself saying "Man I'm not dealing with switching out attachments, I'll do that next week."
I meant to ask you earlier if the attachments you have now are IMatch compatible? If so I would go that route. I would then by IMatch compatible implements in the future too. You can get the IMatch with auto connect for the pto too.
For years I used the 4x4, pinchbar and sledge hammer to attach implements. I am past that now, with roughly 20+ 3PH implements I don't hesitate to swap them out now.
I find that using your head more and your back less is important. I will often change implements several times a day without a problem. If you have a cement floor the casters that a few have mentioned makes sense. If not or you are a cheapskate, like me, just drop your implement on 4x4 or 2x4 sleepers and even a heavy implement can be bumped a bit. Sometimes a long prybar helps. Learning to back up straight and centered is the main thing.
If you are having trouble removing the lift arms from an implement it's usually the top link that needs adjusting. Once it's off there should be no pressure on the lift arms
For me the pto coupling is more annoying than the hitch. Using a little grease makes it easier.
If you are having trouble removing the lift arms from an implement it's usually the top link that needs adjusting. Once it's off there should be no pressure on the lift arms.
