3 point buzz saw
   / 3 point buzz saw #11
I had one for years. I do not burn wood anymore. A great tool for cutting fire wood.
It's called a BUZZ SAW for a reason. I hope you are using hearing protection.
   / 3 point buzz saw #12
I like the video on shingles I had never given a thought as to how they were made.
The Buzz saw I have is similar to the pictures posted. Bought in mid 1980s cost me 450 dollars. Ive used it one year alot and then it may sit for a year or maybe two without use. But either way I don't think I would part with it.I mostly bought it to cut the smaller limbs and I have to cut some wood to under 12 inches in length so its worked well for that.
One word from me is footing..I find I pay it a little more respect than i do other devices. Not that I'm reckless with the others but I am more aware with the potential of the saw.
But I try to have level ground and keep it as clear as possible of small pieces and things that could make me make a mistake.
I have sharpened it a few times with a right angle grinder also..
I also find that I am more likely to cut up limbs that would normally be tossed to the rot pile Some so small they would catch on the chain saw ..
   / 3 point buzz saw #13
Looks plenty safe to me,The guards look like they will do the trick. I have seen many over the years that were scary.**** a chain saw has no guards.The tool whatever it is , if used wrong will cause really alot of damage. Skin cuts easy.
I would look into one, but I would not be able to pick up the wood an put it on the table.(bad, very bad back)but i can use a 16" chain saw ok for a short time.
Army Grunt
   / 3 point buzz saw
Thanks for the shake shingle video.........really cool! Can you imagine slicing cedar with an axe then draw shaving each shingle so they would lay flat. Then this contraption comes out! I will post a pic of the blade that came with mine in hopes someone here can tell me its use.
Back in the 70's, there was never a thought on using ear protection. But my dad sure was concerned when it came to the music I listened to!
chopped,
You hit the nail on the head, footing. That was/is my main concern.
   / 3 point buzz saw #15
Here is a video of the shingle mill. There are others to be seen at the trailing edge of this one.
YouTube - Lane Shingle Mill
Very nice set up there!! Only other thing I can say is that I would take the time to walk around the tractor and not step over that spinning pto shaft it has the power to rap you around it causing you to loose a leg or your life and it can happen all to fast!!!
   / 3 point buzz saw #16
Me, my dad, and my Grandad... about 1953 or so. Powered by a Farmall A with a belt. Guards? What guards? Nobody lost any limbs, but as I remember dad was pretty cautious around that beast.
   / 3 point buzz saw #17
Looks like it is covered with the safety shield. Not the best, but also looked pretty inefficient to have the blocks located so far away from the loading end of the shingle mill.
   / 3 point buzz saw #18
Man, I would be a nervous wreck using one of those things. I cut my thumb off with a circular saw a few years back ( it was re-attahced by the way) and that thing right there gives me nightmares !!!
   / 3 point buzz saw #19
From the ages of 10-17, I rode one end or the other of a belted buzz saw powered by a Farmall H. No table return springs or blade guard and no hearing protection...what? It looked and sounded very dangerous but worked with caution, I don't remember even one "close call". I can't say that for my chainsaw memories.
Crazyal,
Can you get a pic of the shake set-up? Mine came with an extra 30" blade and a smaller blade marked "shingle blade". Didn't know if this blade could be used with this saw. Bought from a dealer that took it in trade so, all he knew was that it came with the saw. thanks
Not until spring. It's covered and has over a foot of snow on it.
   / 3 point buzz saw #20
That's very close to the one my neighbor has. I think that one has more guards on it. It very neat to watch run. His has different blocks that adjust how much it increments the logs. I couldn't believe just how fast that blade will cut a shake.
He got it free along with the buzz saw. The guy who owned it said it came with the farmhouse. He thought my neighbor was going to sell it for scrap. I watch Kevin turn a pile of cedar logs he got for next to nothing into enough shingles to side a house, and not the thin low quality ones you can get at the lumber yard.
P.S. Those shavings are very flammable.
JOHN DEERE 310SL BACKHOE (A60429)
JOHN DEERE 310SL...
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2003 Freightiner FLD120 (A56438)
2003 Freightiner...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
