3-PT Concrete Counterweight
   / 3-PT Concrete Counterweight #11
I just built a custom fitting 3PH, 1,000 lb concrete counter weight for my L3400. It is curing in the garage wrapped in plastic. Once curred, I will submit photos of my new baby!
   / 3-PT Concrete Counterweight #12
I have the 5740, but with the grapple on the front picking up 35' logs to cut and the rear tires are filled, the tractor is tippy. My 8' box scraper or my kubota ballast box only adds between 500-700 lbs. So I took some solid 8" steel stock x 4 by the width of the 3 point hitch arms, welded a CAT 1 pins to it, and it adds 2200 lbs to the rear of the tractor and it is very small. Easy to hook up too. If you are going to lift heavy in front, put heavy in rear. Esp with logs that overhang on each side of the grapple.
   / 3-PT Concrete Counterweight #13
very cheap and usefull. i love casting concrete weights..
can't wait to see your pics!
   / 3-PT Concrete Counterweight #14
Still in garage but will post outside pics later:
   / 3-PT Concrete Counterweight #15
thanks. looks nice
   / 3-PT Concrete Counterweight #17
Looks good, cheap too.:thumbsup: Is the speedway still going over there? Thats were I caught the racing bug, expensive habit.:D
Dave
   / 3-PT Concrete Counterweight #18
I might start grabbing up all of the busted bags at lowes and home dept to make one.
   / 3-PT Concrete Counterweight #19
Dave
I have at most $50 into it...How can they manufacture, bag, and ship a 60 lb bag of concrete mix then sell it for $2.25?
Still racing at Hartford and Hussets.
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2017 Genie GTH-5519 (A53317)
2017 Genie...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
