3 PTH pins, 3/4" on lower link, Where to buy?
   / 3 PTH pins, 3/4" on lower link, Where to buy? #1
pdsrms
Central NH
Kubota L39, B21
I have a small rake that requires 3/4" pins for the lower links. The standard 7/8" ones are too large. Does anyone know of a place to buy these pins?
I'd rather get the pins for $5 than spend $20 for a 1" drill bit that I'll likely never use again.
   / 3 PTH pins, 3/4" on lower link, Where to buy? #2
Tractor Supply has more pins and such than you'll know what to do with. Do you have a local store? If not, any major farm store (Big R, Rural King and others) should have the same. For internet, try searching for Agri-Fab, they make a lot of that sort of stuff.
   / 3 PTH pins, 3/4" on lower link, Where to buy? #3
Agri-Supply has them. Page 56 of the November 2006 catalog. Part # 61508, lift arm pin. Price is $3.79 each. That's more than twice the price of the 7/8" lift arm pins but they're not as common.
   / 3 PTH pins, 3/4" on lower link, Where to buy? #4
Perhaps you'd double check that 3/4" measurement, a Cat 0 lift pin is 5/8" diameter. Cat 1 is 7/8" diameter.
But it may not be as simple as just picking up a set of Cat 0 pins at the farm store. Since there's no tractor info in your profile to reference, I have to ask; what is the inside diameter of the swivel balls on the tractor's lower lift arms?
//greg//
   / 3 PTH pins, 3/4" on lower link, Where to buy? #5
Scratch my reference to Agri-Fab, Mad has it right with Agri-Supply. Thanks MadReferee!
   / 3 PTH pins, 3/4" on lower link, Where to buy? #6
Obviously most tractor dealers also have a good supply of common size pins.
Andy
   / 3 PTH pins, 3/4" on lower link, Where to buy? #7
SIR,
the solution to your problem would be to drill out
the holes, then buy 7/8in pins. please do not drill it
1in, for a 7/8in pin. check your friends, and see if
someone can help you with this. they may have a
proper size drill.
good luck with your projects.
accordionman
wlbrown
wright city, mo.
   / 3 PTH pins, 3/4" on lower link, Where to buy? #8
If you use pins too small for your hitch ball ends, would that not damage the balls? Time to buy the bit. Everyone needs a set of big bits.
   / 3 PTH pins, 3/4" on lower link, Where to buy? #9
Do you have a torch?
2002 Ford Econoline E-250 Cargo Van (A59230)
2002 Ford...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2017 Ford F-250 Pickup Truck (A59230)
2017 Ford F-250...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
