3320 Stops running
   / 3320 Stops running #1
barrest
Sealy, Texas
MF 135
Zetor 3320. 1991 year
Runs for about 20 mins then just quits. Release the bleed nipple and crank and she starts, runs 10-15 mins and quits again. I’ve replace the pump, both fuel filters and all rubber fuel lines. I’m not a diesel mechanic.
Any ideas??
   / 3320 Stops running #2
G'day Mate. Have you put an inspection camera down into the fuel tank to look for any 'crud' (biological growth or debris) that would be blocking or restricting fuel getting to the system?
I ran a hose from the filler neck of the tank direct to the filter inlet bypassing the tank feed pipes. Same result, 20 mins of running then quits, bleed the system and it runs for 15-20 mins then quits again.
   / 3320 Stops running #4
Hmmm... well 'something' is blocking, what I suspect, is fuel continuing to reach the injectors. I mean, the whole system 'works' for 15-20 minutes and there's only 3 things that you need for ignition = fuel, air, and spark. If it 'works' for 15-20 minutes there must be sufficient air & spark (compression) for it to operate... that leaves fuel, which sounds like there's enough fuel after 'pausing' for some sort of 'reservoir' of fuel to gather which isn't being regenerated.
Sorry, but someone else is going to have to join the thread to offer an alternative solution.
   / 3320 Stops running #6
Is the pump you replaced a lift pump? Is it electric or mechanical?
It’s mechanical and bolts to the injector pump. Would an electric pump delivering fuel to the injector pump directly, bypassing all the filters work and if so what psi and volume would it need to be? The return line for unused fuel would remain connected. I need to have the filters I know but I need it to run for more than a few minutes to eliminate the injector pump.
   / 3320 Stops running #8
I’ll give it a try. I have a spare pump in the barn
Should there be foam/small bubbles in the glass bowl on the primary filter?
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
DEUTZ MARATHON...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
