3pt Sander ??
/ 3pt Sander ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Does anybody known of a 3pt spreader made for sand that will
go on a 30 hp Kabota. Ive found some that will spread salt but none
for just sand.
Thanks.
/ 3pt Sander ?? #3
I agree with Mapmaker on the cone spreader. I mix sand with bermuda seed and usually use 100# of sand to 5# of seed. As long as the sand isn't wet it flows just fine. I've lived in the NE and sympathize with your need to sand your driveway....I used cat litter.
/ 3pt Sander ?? #4
I am in the same boat....the dealer Reccomended the Herd but to the toon of about $1360 I didn't want to go that route. I have seen the cone spreaders and wondered if they would do the job. Problem is all the sand I will get is from the Town Hwy Dept which stores the sand outside for residents to use. So basically its wet or frozen....I am wondering if a reciever hitch mounted spreader on my pickup is a better way to go....
/ 3pt Sander ??
mapmaker, when you say "basic cone spreader" do you mean any thing that
will handle salt/sand or can I get away with a seed spreader?
By the way you must be in my area, Im in Waterford.
/ 3pt Sander ?? #6
I use a King Kutter seeder/cone spreader. It worked great for me but the sand does stick a little. I too keep my RPM's low to keep the bulk of the sand on my driveway. I have to bounce the 3ph a little when the sand sticks to get it flowing.
I paid about $400 for mine. I don't mix salt in with my sand so hopefully it will last a lot longer. My driveway is 1800' long, steep, and icy.
Here's a photo of my set up.
Good luck.
Craig
/ 3pt Sander ?? #7
Gordon,
Mine is just a fertilizer spreader. I picked it up used for $250 about 3 years ago. looks exactly like the one in hammys picture. (except mine is green) BTW I am about 35 or 40 miles south of you in Fairlee.
/ 3pt Sander ??
Hey guys thanks;
My driveway/road is a mile long but there are just a couple short hills
I need to sand some times like this winter. I get worn out using a hand shovel. A couple hundred sounds alot better than $1200. Thanks for the picture Hammy.
Gordy
/ 3pt Sander ?? #9
When I saw "3pt Sander" I thought it must be some kind of woodworking tool. I was trying to figure out how I was going to get the tractor into the living room to work on the floor... Never mind.
/ 3pt Sander ??
well you made me laugh and that's not a bad thing
/ 3pt Sander ?? #11
mapmaker said:
Gordon,
If you go that route aa couple of things that might help is to fashion out of sheet metal a pair of diverters that force the sand down as it exits the spreader. I found that it just spreads too wide of path. Another thing is that you might want to try and fashion a slightly stiffer agitator. Mine uses what looks like a thick hairpin. I drilled out my hole and pinned on a small metal plate.
Also silicone or something else on the tub helps keeo the sand from clogging.
Andy
/ 3pt Sander ?? #12
One other thing I did to the spreader was to replace the cups on the spinner with 1/2" by 1/2" inch angle iron. These keep the sand from getting thrown as far. The spreader doesn't do double duty, I only use it for sand so I don't need a greater throw. I am also considering making the openings at the bottom larger so the sand comes out faster.
/ 3pt Sander ??
Thanks again - sounds like good yankee engineering
Freightliner Cascadia (A63689)
Freightliner...
2022 Bobcat E42 (A64126)
2022 Bobcat E42...
(5) FOSTER 10' X 20' STEEL MATS (A64276)
(5) FOSTER 10' X...
2010 John Deere 4720 (A64126)
2010 John Deere...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
