3pt Sander ??
/ 3pt Sander ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Does anybody known of a 3pt spreader made for sand that will
go on a 30 hp Kabota. Ive found some that will spread salt but none
for just sand.
Thanks.
/ 3pt Sander ?? #3
I agree with Mapmaker on the cone spreader. I mix sand with bermuda seed and usually use 100# of sand to 5# of seed. As long as the sand isn't wet it flows just fine. I've lived in the NE and sympathize with your need to sand your driveway....I used cat litter.
/ 3pt Sander ?? #4
I am in the same boat....the dealer Reccomended the Herd but to the toon of about $1360 I didn't want to go that route. I have seen the cone spreaders and wondered if they would do the job. Problem is all the sand I will get is from the Town Hwy Dept which stores the sand outside for residents to use. So basically its wet or frozen....I am wondering if a reciever hitch mounted spreader on my pickup is a better way to go....
/ 3pt Sander ??
mapmaker, when you say "basic cone spreader" do you mean any thing that
will handle salt/sand or can I get away with a seed spreader?
By the way you must be in my area, Im in Waterford.
/ 3pt Sander ?? #6
I use a King Kutter seeder/cone spreader. It worked great for me but the sand does stick a little. I too keep my RPM's low to keep the bulk of the sand on my driveway. I have to bounce the 3ph a little when the sand sticks to get it flowing.
I paid about $400 for mine. I don't mix salt in with my sand so hopefully it will last a lot longer. My driveway is 1800' long, steep, and icy.
Here's a photo of my set up.
Good luck.
Craig
/ 3pt Sander ?? #7
Gordon,
Mine is just a fertilizer spreader. I picked it up used for $250 about 3 years ago. looks exactly like the one in hammys picture. (except mine is green) BTW I am about 35 or 40 miles south of you in Fairlee.
/ 3pt Sander ??
Hey guys thanks;
My driveway/road is a mile long but there are just a couple short hills
I need to sand some times like this winter. I get worn out using a hand shovel. A couple hundred sounds alot better than $1200. Thanks for the picture Hammy.
Gordy
/ 3pt Sander ?? #9
When I saw "3pt Sander" I thought it must be some kind of woodworking tool. I was trying to figure out how I was going to get the tractor into the living room to work on the floor... Never mind.
/ 3pt Sander ??
well you made me laugh and that's not a bad thing
/ 3pt Sander ?? #11
mapmaker said:
Gordon,
If you go that route aa couple of things that might help is to fashion out of sheet metal a pair of diverters that force the sand down as it exits the spreader. I found that it just spreads too wide of path. Another thing is that you might want to try and fashion a slightly stiffer agitator. Mine uses what looks like a thick hairpin. I drilled out my hole and pinned on a small metal plate.
Also silicone or something else on the tub helps keeo the sand from clogging.
Andy
/ 3pt Sander ?? #12
One other thing I did to the spreader was to replace the cups on the spinner with 1/2" by 1/2" inch angle iron. These keep the sand from getting thrown as far. The spreader doesn't do double duty, I only use it for sand so I don't need a greater throw. I am also considering making the openings at the bottom larger so the sand comes out faster.
/ 3pt Sander ??
Thanks again - sounds like good yankee engineering
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2014 DODGE RAM HEAVY DUTY INSULATED BUCKET TRUCK (A63276)
2014 DODGE RAM...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2006 KOMATSU FD80T-8 FORKLIFT (A67148)
2006 KOMATSU...
Chevrolet Metal Tailgate Sign (A64557)
Chevrolet Metal...
