EddieWalker
Epic Contributor
Rob,
If I had a FEL I would dig a big hole and make a burning pit. Burning in a pit is so much safer. Plus you know you will always be burning going forward every year.
On our farm we have the next best thing, a borie that is caved in and 3 side walls are standing and the front wall destroyed. Looks kind of like a horse stall without a gate. A burning pit is a good thing.
Rox,
I can't speak for Rob, but my experience with burn piles is the danger is from the embers. Get a hot fire, or certain types of fuel in the fire, like leaves, and they float into the air. When they land, you have the possibility of a fires being started. I've seen them floating up and over me while I'm sitting on the tractor.
Another problem is that a pit holds water. Even if it drains, it will hold water for a period of time. Then you have to wait for it to dry out before even thinking of starting the fire. Some of the best times to burn are right after a rain. If the pit is full of water, you are not going to get much of a fire since a good burn only comes from a good set of coals.
Then there is the problem of the ash building up. After trying just about every combination of burn piles and cleaning them up, having it out in the milldle of a field on a slightly sloping ground works the best. You can add to it from any side, and get to it to punch it up and keep it going from any side. This is important on big fires because they get so hot and smokey that from the wrong side, it's impossible to get to it, but on the other side, it's fairly easy.
There is also leftovers that just didn't burn, no matter how hot or how long you burn, some will always be left over. In a pit, you can't do anything about that. On the flat, you can restack it and burn it next time.
The more you burn, the more ash you end up with.Cleaning the ash up is easy with the FEL, but a muddy mess in a pit. Even after burning for a week or two straight, you will still have mud just under the surface.
A burn pile is nothing like a camp fire. Not even close.
Eddie
