4.5 grinder recommendation?
   / 4.5 grinder recommendation? #1
herm0016
Platinum Member
Carter lake, Colorado
Branson 4720h
finally wore out my slim grip rigid 4.5 grinder.
I really liked the trigger setup and grip on this, but do not see any like it now.
thinking about getting a made in Germany metabo. any other recs? seems like in the 100ish dollar price point, you can get about any of them. I am a fairly light user, but appreciate a quality piece. never really felt like i needed a ton more power with the orange one, rated at 7 amps. Metabo rated at 8.5. the 11 or 15 amp rated ones look quite a bit heavier/larger on the grip.
   / 4.5 grinder recommendation? #2
I have a DeWalt DWE402W and really like it. I had a 7 amp (I think) Black and Decker Firestone before which was nice, but the DeWalt just never runs out of power...
Aaron Z
   / 4.5 grinder recommendation? #3
Like wow man, the colors!!!1
It's weird enough to see a post come up on another tractor board, but to see it on a completely different topic board is like really farrrrr out man!!!
   / 4.5 grinder recommendation? #4
had something i bought at a partsarama 20 plus years ago, the cord/motor connection got funky, spent $10 w/ coupon at harbor freight...seems fine to me. came with wrench and spare brushes.
   / 4.5 grinder recommendation? #5
I like the Bosch paddle grip models.
   / 4.5 grinder recommendation? #6
In 4.5 inch grinders my fave would be the 10 amp Makitas but my 8 amp Walter is pretty nice too with a slimmer grip.
are you on anandtech? whats your handle over there?
   / 4.5 grinder recommendation? #9
Check out the variable speed grinders too. They have their place for cleaning and finishing. Gives you that variable speed type of feel.I have a Walter that has variable and it has been great.
   / 4.5 grinder recommendation? #10
From what I’ve seen their are 3 types of triggers. That will be your big ergonomic factor. The way the guard works is also a factor- some have quick swivels and some require some effort to move. Beyond that I haven’t seen anything that will significantly outdo another. The 4.5” grinders with soft start feature probably won’t really make much difference....but maybe something to think about.
   / 4.5 grinder recommendation? #11
Regarding types of triggers.
I like slide switch locked on for grinding wheels and cupped wire brush and paddle switch for zip cut wheels and circular type wire brush.
   / 4.5 grinder recommendation? #12
Before I retired I noticed Metabo was the grinder of choice for the Boilermakers who did the outage work in our plant.
   / 4.5 grinder recommendation? #13
I have three on my bench and a new spare in the cupboard. I don't know if it is the amperage (10) or the brand, but I like my DeWalts. When I retired, I gave my Makita and something else to my kids as they felt under powered and I no longer needed them as spares.
   / 4.5 grinder recommendation? #14
It's been a few years since I was working on air tools, but the best by far, and of course most expensive, were the Sioux tools, including their grinders.
   / 4.5 grinder recommendation? #15
I have 3 with the Dewalt being the best built and most expensive of them all. One of them is a HF model and it is significantly lighter but has held up for many years and works as well as the Dewalt. These are used in a hobby environment, not in any kind of professional capacity.
   / 4.5 grinder recommendation? #16
I'm a fan of buying 5 cheap Harbor Freight grinders for the price of a single nice grinder. At $20 each they are disposable & you can have a few with different wheels on ready to go without grabbing wrenches.
   / 4.5 grinder recommendation? #17
I have 2. one is a 4.5" and the other is a 9". they lasted 3 years so far, the 4.5" has plenty of power, but the 9" can't be stopped by anything!.. I only buy good quality wheels, though. they out last the Harbor Freight wheels by a good margin!..
harbor freight consumables are junk. i found a dewalt sale at a local murdochs, and got a great deal on dewalt wheels and stuff, so i have a good stock of them now.
kept being tempted by the metabo, so ordered that one. thanks for the recs though. i may pick up a VS one as well, sounds interesting. have not used one before.
   / 4.5 grinder recommendation? #19
Couple of thoughts. Welder ueses
Metabo...
I have had many years with my made in USA Milwaukee.
Harbor Freight 3 strikes for neighbor and his gate project... the wire cup attachment destroyed all in minutes
   / 4.5 grinder recommendation? #20
HF 11 amp grindet
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2014 F-150 STX (A56438)
2014 F-150 STX...
