Ok, drove the JD 5105 and used Kubota
M6800 this past weekend. Really didn't like the
M6800 - the
M7040 has A LOT of improvements even though I can see it was engineered by the same people. I will say that the
M6800 was quieter and had less vibration than the JD5105, and had a noticeably tighter turning radius (even though I think their paper specs are pretty close for turning radius).
The JD 5105 was pretty impressive. It is basic, but it is built massively and everything seems well engineered, even if not the latest technology (e.g. dry PTO clutch). It drove nicely and everything worked great. I could definitely buy that and be happy. BUT... for a few hundred $$ more the
M5040 would have several more features, including the hydroshuttle that the dealer is strongly encouraging me to get. I haven't ruled it out and I'm hoping to drive the
M7040 again this weekend for more thoughts (that dealer's
M5040 is still on order, he doesn't have a firm date for its arrival).
A few questions:
1) The Kubota dealer tells me you can wear out a dry clutch very fast doing FEL work, and he had one customer wear one out in under 200 hours. He tells me I should definitely get the hydroshuttle with wet clutch - a $1200 option vs. what he tells me is $2500 to replace a clutch. However, the JD dealer tells me that clutches last so long I shouldn't worry about it, and if you wear one out in 200 hours you're doing something wrong. Who's right? Do I need the wet clutch? I am planning on a decent amount of FEL work but it's definitely not the only thing I'll be doing. Are there any disadvantages to the wet clutch? Do they cost a million dollars to fix when they finally wear out or fail?
2) Is there any meaningful data on longevity and durability between JD and Kubota, or is this just a Ford vs. Chevy type thing?
3) The
M5040 FEL has a skid-steer quick attach while the JD has a JD-proprietary quick attach. They seem about equally easy to use, but I would imagine that the skid steer attach gives me a lot more options for special buckets, forks etc. Is this likely to be true? I looked at the line-up of FEL attachments on the JD website and I wasn't impressed at what was available for the 522 - it looked like a bale spear and pallet forks were about it. Of course, that might be all I ever need - hard to know at this point.
4) The FEL hydraulic hoses on the JD 5105/522 loader hang down quite noticeably below the tractor. I have to think that they are at risk of getting snagged and even cut when doing fieldwork like brushhogging. Anyone have any problems with this? Or can someone convince me that this won't be an issue? It appears that the
M5040 has a metal shield protecting the FEL hoses, which otherwise do appear to hang down in the same place.
5) The
M5040 and virtually all Kubotas has a hydraulic PTO control, while the JD has a manual lever and a dry clutch for its independent PTO. Is there any meaningful difference here?
6) According to the Nebraska tractor tests, the JD 5105 is extremely stingy on fuel usage relative to its PTO power - a big plus with our diesel prices here (and in the future, IMHO). They don't have a test for the
M5040 or any Mxx40 series. Can anyone with a 40 series tell me how their fuel usage fares?
Thanks - I'm nearing the end of my selection process.
