OP
coloradotrout
- Joined
- Aug 19, 2005
- Messages
- 388
- Location
- Eastern KS
- Tractor
- JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Why do I sense I need to somehow cleanout the injectors?
Remove them and clean them in diesel. First see is fuel getting to the pump...is the fuel pump working? Does the fuel tank relay engage and flow fuel when you turn the key?
I'd more suspect the glow plugs rather than injectors. I've had 3 diesel cars and 2 diesel tractors and now also have a diesel generator. The first two diesel cars had lots of miles on them. I've never had to touch the injectors on any diesel equipment yet. The 2nd car had 2 of the 4 glow plugs go out at around 250k miles and over 20 years.
Get a voltage checker and put the positive contact onto one of the glow plug wires and the negative to ground. Check that you get voltage with the ignition key in start position and the PTO turned on.
If all 3 have voltage, then I'd remove them to see which ones are bad. If you have a continuity checker, you could put one side on the top terminal of the plug and the other to ground and see if there's a continuity to determine maybe which one is bad. The burned out one(s) won't have any continuity through the plug to ground.
Ralph
