Backhoe 447 Backhoe teeth replacement
/ 447 Backhoe teeth replacement #1
jba3520
Bronze Member
Eatonville, WA
JD 3520
Has anyone here been able to get the original forged teeth for the 12inch bucket. All I can find are the welded teeth and they don't hold up. The dealer says the welded teeth are the replacement p/n T2A
/ 447 Backhoe teeth replacement #2
/ 447 Backhoe teeth replacement #3
If you can't find the old type teeth --- try hardsurfacing the welded ones. That's what I ultimately did. Run a bead around the leading edge of the tooth and down the face, too.
Good luck.
AKfish
/ 447 Backhoe teeth replacement #4
I too am looking. If you look back you can find pix in a previous post of mine. My issue wasn't the wear surface wearing out, it was the thin metal shell. They distort and then the tooth falls off. Next week I am taking a trip to the big town and am going to take a sample by the bobcat (r) dealer and see if their teeth are made better.
I unlike some have had no issue with the root breaking off.
2019 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A66736)
2019 Peterbilt 579...
2022 Suzuki King Quad 500AXI 4X4 ATV (A66738)
2022 Suzuki King...
Unused 2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 IDeal...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
CAT 953 4-in-1 Bucket (A68134)
CAT 953 4-in-1...
