4720 rat problem
/ 4720 rat problem #1
Philthefridgeman
Cairns queensland
John Deere 4720 cab hydro . Can I install a battery isolator switch as I have rats in my shed and worry about the fire risk. Will turning off the battery effect the computer? Thanks Phil
/ 4720 rat problem #2
Good Morning Philthefrigeman and welcome to TBN. I have a few suggestions.
- keep the hood open on your JD when not in use. I have mice and chipmunks. Neither like the open spaces of an open hood. This seems to be about the best solution - and I've tried most, at least one time. Barn cats are the ultimate answer. If you can keep the coyotes, owls and hawks from eating them.
- your on-board computer for the tractor should have a battery backup to protect the memory. Disconnecting your main starter battery should not affect the computer memory.
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
2003 Bombardier Evinrude 75 Outboard Boat Motor. (A66738)
2003 Bombardier...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2011 BRENNER TANK 200BBL CRUDE TANKER (A67714)
2011 BRENNER TANK...
2021 CATERPILLAR 316FL EXCAVATOR (A65056)
2021 CATERPILLAR...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
