640 with loader
/ 640 with loader
What oil for the transmission on the 640, also what oil goes in an SOS trans
/ 640 with loader #32
I use the Universal Tractor Fluid (UTF) in both the transmission and hydraulics. I think that most folks do the same. I have no knowledge about your SOS tranny.
/ 640 with loader
Thanks for all the info, hope someone will chime in on the SOS oil
/ 640 with loader #34
hyds holds about 2g of utf fluid.
I'd put utf in the trans and diffy for now too.
you will soon be replacing the filed points.. but for now they will be fine.
rings may be stuck from setting.
put a quart of atf into the oil, and a half quart in the gas. pul lthe plugs and put a couple tablespoons down each hole and let it set a day.. run the engine over with plugs out to slig the oil.. then start back up...
/ 640 with loader #35
sos trannies most deffinately take a UTF oil..
/ 640 with loader
Did a little cleaning on the 640
/ 640 with loader #37
interesting rears.. what size are they?
check out the frotn axle.. i detect some bowing in the radius rods.
/ 640 with loader
The rear tires are 13.00 x24 there are from my forklift, the tires that came with the 640 we put on the 8N, yes the front axle is about shot I'm gunna have to go get it bored and bushing back to std and get a new pin. As for the radius arm it is a little bowed but the right isn't the trunion balls have a lot of wear and slack
/ 640 with loader #39
unless the balls slip out of the socket completely.. they are a non issue.
a chain and bottle jack can usually straightent he arm.
a metal slug, lead weight or penny can be put int he socket behind the ball.. so can a piece of inner tube.. works great..
/ 640 with loader
Anybody have a halfa$s good hood for a 600 series. I have nothing so anything would be better than nothing
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
