6520 4WD tire pressure
   / 6520 4WD tire pressure #11
My 6000 came with R1s filled with non toxic RV type antifreeze. I have done exactly what you are doing for going on five years now with my 6000 and R1s. Don't doubt the sturdiness of the tires. I'll take the traction over the load capacity. Why? I'm already hauling everything I can counterweighted (and sometimes lifting the wheels) with no tire issues. The Mahindra loaders might be a little slow to some, but man do they lift. I'll just keep on doing all I do with my R1s and when they wear out I'll get new R1s.
   / 6520 4WD tire pressure #12
bindian said:
Brian & Spyderlk,
Guess when these wear out, I will see about finding a higher rated R1. I am sure that would be cheaper than new R4s and rims. I am guessing R4s on front and R1s on the rear would work. But it will look odd. ;) hugs, Brandi
I really wouldn't try R4s in the front and R1s in the back..different profiles, and gear ratios will make "something" wear faster......6000 comes with 11.2x24s in the front...My FEL will also do the 3900lbs...never had an issue with "flattening" fronts.. Not sure if the 11.2s will fit on your rims, but would be worth the time to ask....BobG in VA
   / 6520 4WD tire pressure #13
Brandi and Brian, I like the predominate advantage of the self cleaning tire for traction in most situations, as well as the larger diameter too - which also helps traction and ride quality, and ground clearance. It is for these advantages that I would never go to R4s, perhaps even if I were doing 100% loader work on surface conditions here. Admittedly, the fronts become grossly overloaded when carrying full loader capacity. Lets see- tractor,BH,FEL, loaded rears--12,000#... bucket load 4000#. The rears get light. That means theres somewhat less than 16K# on the fronts. At unladen fill 30psi air the tires are near flat. The question for me is what pressure the tire will safely accommodate. The side panel on both the rear and front tires gives warnings about using more than 35psi to seat the bead. Yet the max operating pressure of the rears is 18psi, while the front is 30psi. This is inconsistent with logic for differently sized tires having 6 ply rated carcasses. Due to its smaller size and therefore lesser area the small carcass is not strained as much per psi as the larger one. I know for a fact that the fronts will withstand 80psi because I accidently got one to that by leaving the water on too long while in the last fill - bleed cycle. There wasnt much air in it so not super dangerous. That low compressable content is whats so good about making the R1 work safely for much higher loads. My tires now have 16psi. I initially set them at 20, but some of the air has been absorbed into the water. The tires ride better, and carry loads better than they did empty at 30psi. They are filled to just above the valves at 12 oclock - a little less than 75%. I plan to keep pressure in the 18 to 20psi range and go as high as 90% fill to get load support. The pressure will go higher with squat from FEL load - maybe as high as 50 with care on bumps- but Ill be far from the tire. I know the carcass will stand 80psi, and the benefit of limiting the extreme [and harmful] distortion seen by the 30psi empty tire is worth it to me. Another way, if you could be sure youll never change your mind, would be to foam fill. For me -too permanent.
Brandi, yes rust is an issue, but the rims are painted. Even CaCl leaks take years to rust out a rim. Even in freezing territory I choose water for convenience. I keep shaving trees with the rims and that causes a bead leak until you remove the morsel. Its great to be able to just let some water out to soften the tire so that it comes out easily and completely. Or you could just let it seep for awhile - no big deal.
larry
   / 6520 4WD tire pressure #14
Bob, I have 11.2s and @ 30psi they flatten on 7520 at full FEL load. You may have a longer wheelbase or else less front over reach with the loader. Thats the only thing I can think of.
larry
BobG,
Now that has me puzzled.:confused: My R1s on my 6520 are just 9.5 x24s. Why would they put a narrow tire on the 6000? :confused: :confused: When it will lift the same as your 6500? :confused: :confused: :confused:
hugs, Brandi
   / 6520 4WD tire pressure #16
bindian said:
BobG,
hugs, Brandi
That would be to match front/back circumferences to the 4wd axle ratio.
larry
larry
Ok, I understand now. It wouldn't matter what was (is) in front on a 2WD.
hugs, Brandi
   / 6520 4WD tire pressure #18
Brandi,
Can't seem to locate it just this minute, but there are tables for the various tire sizes and what they take in water weight (and/or water/methanol mix) at various fill %ages. Might try googling "water filled tires" and see what you can find.
My 6500 fronts worked out to about 250# each with water/methanol mix if I remember correctly.
VistanTN said:
Brandi,
VistanTN,
I will google it. :)
hugs, Brandi
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 GMC Savana (A50120)
2018 GMC Savana...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
