6520 4WD tire pressure
   / 6520 4WD tire pressure #31
bindian said:
Brian, :D :D :D They are like a sail cat, something you don't want to pick up.:rolleyes:
hugs, Brandi
Now I thought the whole idea of a "sail cat" was to pick it up... and make it fly through the air like a frisbee... no? :D
bindian said:
Tim, Thanks for the input.:) I guess that is another goal I can go far with my Mahindra............lifting so much weight it blows the front tires. :D Have you ever changed a tire with foam in it? It ain't fun.:( I have decided to just use air for now and inflate to max inflation. I should have checked tire pressure when I just got the thing. I would imagine it was over inflated, as I have lifted that much before and the tires didn't go down that flat.
hugs, Brandi
This brings to mind a topic that I'd meant to ask about in a general forum on TBN... the use of those heavy, solid-rubber, semi-pneumatic skidsteer tires on a compact (or even not-so-compact) tractor. Since my front tires are essentially skidsteer tires anyway... and since it would be awfully nice not to have to worry about front punctures anymore (of which this tractor of mine has already had two)... when the current fronts wear out, does it make any sense at all for me to consider those expensive semi-pneumatics??? :confused: Possibly even going to more aggressive, over-wide tires at the same time???
Dougster
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
John Deere 331G Compact Track Loader Skid Steer (A50322)
John Deere 331G...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
