66 vs 60 loader bucket?
   / 66 vs 60 loader bucket? #11
By the way, I have the 66 inch Kioti bucket, and I still have my 60 inch Kubota bucket, and I use them both!..that's right I have the best of both worlds, a narrower bucket or digging and a wider bucket for hauling. And a set of forks, for a number of uses. Trust me forks are really worth the money. And I am saving up for a Grapple.. Tractors are just so much more useful when you have options.. Why limit your options? It literally only takes a few seconds to drop and change front implements with a SSQA. When I got my L3400, without SSQA.. it was not long before I realized I had made a big mistake, and it cost me in money and time to reverse that mistake. But hey, each to his own.
James K0UA
When I got the SSQA setup for my B3200 - I got the 54" bucket and the 60" bucket. I also bought a Virnig rock bucket. I started out with a 60" bucket when I got the tractor - and found that I really didn't think the 60" dug all that well (didn't have a toothbar on it) . So I got the 54" too. When I swapping from pin-on QA to SSQA - I ordered the QA and the two buckets. I've been using the 54" for digging - and find that it does dig better than the 60" - I've got a BXpanded toothbar coming soon - and that will get mounted on the 54" bucket , I'll leave the 60" bucket "smooth". That way if I need a bucket with a straight edge - I can quickly swap the 60" on - and I can use the 54" for digging. It's much easier to swap the bucket than it is to bolt and unbolt a toothbar from a bucket.
Since I work on a small property - I'm like ovrszd - I can swap thru all three buckets and the forklift frame easily in just an hour or two's worth of work. If I had to pound out pins to to do that - I would extend a 2 hour job probably into a 6 hour job.
The QA is EASILY worth the money.
   / 66 vs 60 loader bucket? #12
Get it, its a no brainer!
   / 66 vs 60 loader bucket? #13
I had a L3710 with fixed bucket. One major decision maker to trade up was the QA. My first extra attachment was pallet forks. Second came a bale spear. Plus just having the QA gives me the ability to bid on stuff at auctions because sometimes you can get skid steer attachments dirt cheap.
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
