7234 Injector removal/Help
/ 7234 Injector removal/Help #1
F100Panel
Renss. County NY
Usually something with a Loader
I downloaded the service manual posted by Old Machinist. THANK YOU AGAIN SIR... One problem though.. The injectors on my engine & those shown in that manual are totaly different. My bleed off tubes are metal and go in a staright line from injector to injector. I want to get the injectors out without damage/I look on the internet, $300+ each.. I'm guessing first you take out the supply tubes. Then I'm guessing that is a lock nut that holds down the next section of the injector that has the in-line metal bleed off tubes running from injector to injector.. You take off the 3 lock nuts & take that inline assembly off as 1 piece? Then unscrew the injectors from the head? Would I be correct in my guessing?
/ 7234 Injector removal/Help #2
Sounds a little different than what I remember on any other Mitsubishi engine I've had but I think you probably have it figured out. On my current machine, the return line isn't metal and is simply T'ed together sections that have a "clamp" that holds them on the injector. Yes, I would take the fuel line off first and gently bend it out of the way, take the return line loose then remove the injector.
$300 sounds quite high, I have seen a number of different Mits compatible injectors for sale in the $100 range. Find out what number they are and post it here and lets see if we can't locate something cheaper.
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
2020 CATERPILLAR M320F MOBILE EXCAVATOR (A65056)
2020 CATERPILLAR...
2007 INTERNATIONAL MAO25 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
Titan MI 3106 (A64911)
