OP
        HomesteadOC
Just got off the phone with the super nice guy at NCW, pistons are designed to be off axis like that, the squared off nub is oriented toward the fuel injector port on the head. Factory valve seals are the 13mm variety that are included with the top end kit, mine are 14mm and apparently have been replaced at some point in time. He is including a set of the 14mm seals with the new piston and pin I had to buy. Ill have to check my piston when I get home to make sure I had it pressed on correctly. The bearing tabs are on the same side of the rod as one another and those point towards the fuel pump, my rods lettering are orientated towards the front of the engine and the bearing tabs toward the fuel filter so were all set there. But Im pretty sure I have the piston on backwards, Ill give an update when I can get home. As far as the relief on the piston goes, it burns more of the fuel that enters the combustion chamber, not less like ai said a few days ago in this thread. Im not sure how it affects the power, but they are called decompression reliefs so Id imagine the power is decreased with increased fuel burning and exhausts less smoke. Im happy with this compromise, I prefer to breathe less smoke when I operate the tractor. I havent actually driven it with the flat top pistons so theres nothing to compare it to, but less smoke is always better. I also prefer less noise, but Im not sure how I can do that yet. Maybe a stack with an extra muffler?
