8N 6v Generator rebuild?
   / 8N 6v Generator rebuild?
I realize the Armature would be the perfect match but I don't want to risk damaging it since that was the one part I could not find. I thought I was onto something this afternoon thinking about how drill bits are sized to the 64th of an inch so one of those should be pretty close to the right size, but unfortunately the bits I have are the three sided base type so that won't work. Found a screwdriver bit holder that was really close, but the grease still squished out of the hole. I've got it soaking in pb blaster right now, might try the bit holder again tomorrow morning after it soaks a while.
   / 8N 6v Generator rebuild? #12
Take a wooden doll rod and chuck it in a drill and sand down what you need to. Soundguy will not tell you something he has not done or at least seen done. Go for it. The one wire 12 volt would be my choice, but mine has a 8 volt in it right now.
   / 8N 6v Generator rebuild? #13
the dowel rod is a great idea.. can make it a tight fit too.
hyd pressure to remove bushings and such is a good tool if you can make it work. like on flywheel pilot bearing/bushings. e tc.
   / 8N 6v Generator rebuild? #14
ps. things like armature shafts from non rebuildable generators are great for this. get one like that then you have one that fits plenty of stuff.
IE. I have dozens of fords.. so custom tooling is nice.
Well I finally got the bearing out, but it did not want to come easily. I turned down a chunk of scrap wood with my power drill and a strip of sand paper until it was the perfect size to fit in the bearing, but unfortunately the grease then squished out through the bearing itself before it even thought about coming out. Did not have anything to fashion a slide hammer so out came the dremel tool. I sliced through the bearing on two sides enough to weaken it without damaging the end plate. Then with a drift punch, hammer and pair of needle nose I gently coerced the bearing out in pieces. I got the gen. Put back together and on the tractor, polarized jumping the regulator terminals before starting it up, but I'm still not making power. I'm thinking regulator? Shouldn't I get power from the generator even with a bad regulator though?
   / 8N 6v Generator rebuild? #16
On an 8n, jump bat to arm to polarize. Once that is done, to test, get engine to high idle, then check volts on battery, should be 7.2 or so. If not, jump bat to arm to bypass cutout, I still nothing, then jump field to ground, to bypass field circuit.. If either of those work, reg is bad.
I did not get any change in voltage when jumping either set of terminals separately. Should they both be jumped at the same time when jumping the field to ground?
   / 8N 6v Generator rebuild? #18
I didn't say u jumper so yeah, bat to arm and field to ground, there should be a v change even if no charge as the field will load that bat even if armature open, so unless field and arm both open, re check your methodology, or meter.
Im a little confused with your reply here, maybe I worded it wrong... I was checking voltage across the battery + to -, starting voltage was just battery voltage of ~6.2 ish. The voltage did not increase at all during any of the tests (batt to arm then field to ground.) the meter is good, maybe I'm not using the correct method? I have a short wire with two alligator clips that I was using to go between each terminal, clip one end on first screw, then touch second screw with other end, watch meter for changes. If anything I saw a drop of a few tenths during one of the tests, don't remember which as this was a couple days ago. I'm not sure the genny is exactly right either, in my excitement to get the tractor back together, I forgot to do a motor test before I reinstalled it. Think I will start there this weekend.
   / 8N 6v Generator rebuild? #20
if you are using only 1 jumper wire you are not doing the test as i instructed. you would need 2 wires.. and preferable do the field to ground at the genny.
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2016 Freightliner TMA (A52377)
2016 Freightliner...
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
