Add a Double Pilot Check valve to Side Link Cylinder?
   / Add a Double Pilot Check valve to Side Link Cylinder? #21
Thanks for all the input. Let me fill you in on where I've been and where I'm trying to go.
My lane is 3/4 miles up and down along a river. Constant maintenance required. I had a Kubota L3600 with a single factory rear remote and a Monroe 7' HD backblade with a cylinder to rotate it(HEAVY). I added a 3 solenoid valve block plumbed off of the single rear remote. Initially used one position to operate an hydraulic top link and a second one to rotate the backblade. Bought an hydraulic side link through the dealer to allow me to tilt the blade for ditching along and crowning the lane. The cylinder would drop 3 or 4 inches in 10 minutes. Assuming the problem was the cylinder, they dealer gave me a replacement. Still leaked down so I gave up and abandoned it.
I've since replaced the tractor with a Kubota L5240 HSTC equipped with 2 rear remotes so I can operate the top link and blade rotation. Decided to try the side link (kept it when I sold the first tractor--not intensionally--forgot it). Turns out the L5240 has a smaller pin in the upper end of the side link, so I need to determine the right size and replace the upper ball end on the cylinder before I can determine if it can hold up the blade using the remotes on the newer tractor. Does anyone know a source for a new weld on ball end and the correct size for this 5240? The L3600 used a 7/8" pin, but the L5240's pin is smaller and uses locking nuts rather than a pin as a retainer.
Reading through all your responses leads me to conclude that the problem with the original setup was in either the remote on the L3600 or the solenoid diverter block. I want to confirm that the side link will perform satisfactorily through the L5240's remotes. If so, there'd be no need to add a check valve to the cylinder. If I can make this work I may spend the horrendous $ Kubota wants for the kit to add the 3rd remote.
Thanks again for your help. Now I need to find a source for the correct ball end for my cylinder.
Easiest thing to do is to just bush it down in size. I think that you will find that if your side link was the right size working length for your L3600, it is not the right working length for your L5240. Not saying that it won't work, just that it will not be right. You probably can make up the difference by using different pin locations in the lower clevis and use the manual adjust on the left side and dial it in that way.;)
   / Add a Double Pilot Check valve to Side Link Cylinder? #22
Brian , good job of defending your position with logic concerning valve leakage versus cylinder leakage. They dogpiled you for awhile but you prevailed. Heheheh.
Brian,
Thanks for the suggestion.
You are correct. It's not perfect choice for this tractor, but the dimensions are adequate to work for my purposes. I had the cylinder on the tractor last fall. The difference in pin size is so small that I don't think I can find a bushing thin enough. Do you happen to know the O.D. of the pin used on my tractor L5240HSTC? Still have my snow removing armor on the tractor including the back blade or I'd pull it out and measure. Feel like a real deadbeat asking this of a man who makes and sells sidelink kits and I'm trying to cobble up one I already have.
   / Add a Double Pilot Check valve to Side Link Cylinder? #24
Brian,
You should be able to get a bronze bushing that goes from 7/8" down to 3/4". Honestly, my guess is that the L3600 had a 3/4" pin also. Your dealer probably bought a Tisco unit and that is what size pin hole it came with. They just put it on and thought you were good to go. But that is all just supposition. :( Kubota jumps up to the 7/8" pin size with the M models. ;)
   / Add a Double Pilot Check valve to Side Link Cylinder? #25
Oh, you really think so. You assume to much. He He.
So you think they make hyd valves inferior to cyl and charge more for the valves on purpose.
It 's not about someone getting something over anybody else, it is about what one knows and have seen.
Have you seen data backing up either theory, as to whether the cyl is giving the most problem or the valve.
It would really pi** the manufactures/dealers off to be replacing a lot hyd valves.
Maybe one can correlate the ability for a loader to raise and keep the bucket up for weeks or months to either the cyl or the valve.
It is real easy to test the valve by installing a shutoff valve in the work port to the base end of the cyl.
Raise the attachment , shut off the valve and see what happens. If the cyl retracts, then you know it is the cyl.
If the cyl does not retract, then the cyl is presumed good. Now, open the valve and wait, and see if the loader will descend, and if it does, then the valve is leaking.
You can either test using the faulted hyd components you have or use known good parts.
There are other ways to test, and people should fully trouble shoot before jumping to conclusions.
   / Add a Double Pilot Check valve to Side Link Cylinder? #26
You can either test using the faulted hyd components you have or use know good parts.
JJ it's much easier to test the cylinder which was repeatedly explained by Brian. Maybe you didn't hear him because of the commotion during the dogpile. Heheheh.
No manufacturer wants to admkt the factory valve is to blame versus the aftermarket cylinder.......
   / Add a Double Pilot Check valve to Side Link Cylinder? #27
A basic fact of life is that ALL spool valves leak unless they are equipped with check valves. The amount of leakage varies depending on several variables some of which are: roundness of the spool bore, roundness of the spool, diametrical clearance between spool and bore, overlap of spool land on the valve body, oil viscosity, pressure, etc.
I have found very few valve manufacturer's that document valve leakage.
The reason valves are rarely replaced is they are hardened parts that typically don't get damaged or scarred unless some large debris gets caught in them where as seals are wearing components designed to sacrifice themselves to seal. Rubber seals by deforming into or conforming to the mating surface, I.e. cylinder bore which even when honed is not smooth. Typical worst case seal wear is at break away under load. This is when the seal is sitting static under load (pressure) and has conformed to all the minor irregularities in the bore. When first movement occurs there is a chance for very small fragments of the seal to be torn off.
JJ & Others
With a load on an extended cylinder and the blind end port blocked, & if there is NO leakage path out the rod end you can remove the piston seals and the cylinder won't retract. Some times suggested tests are solving the problem either.
I've ordered a bushing so I can hang this side link on the newer tractor. When I get to it, I'll install it and see if it still leaks down quickly. If it does, I'll see if I can determine if the valve or cylinder is at fault and report back. We can't leave this discussion just "hanging out there".
Thanks for all the help.
   / Add a Double Pilot Check valve to Side Link Cylinder? #29
KCOburn,
If it leaks down please measure the actual cylinder drift over time not the implement movement. due to the geometry of the 3 point hitch arms in relation to implement width a a 1/4" of cylinder drift could be inches of implement movement.
good luck
   / Add a Double Pilot Check valve to Side Link Cylinder? #30
That's a good one!!!! Glad to see you have a sense of humor about it!!! :)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
John Deere 5055E (A53317)
John Deere 5055E...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
