Agrotk excavators: Does anyone have one? Opinions/comments/critiques?
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #141
Have you called this place you posted about the ripper I see he has some rippers
I have not. I saw the AGT ripper and I was hooked. I would like to get an opinion on the AGT from the experts on here.
It looks like something I could really rip stuff with! :D I did not see it in the pic of their attachments, but I guess that doesnt mean much.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #142
A Utube poster just measured the weight of his new QH12, as-delivered on a small pallet, and it came in at 1808#. The manifest said 2200#.
The unit now comes with a hyd return filter, which is great news.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #143
Do you know if it has the hyd cooler and fan?
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #144
I did not see one on that unit. What does the importer say? They have so many variations now.
Some new owners are going nuts installing fans to cool the house, without considering how much current the B&S alternator can supply. Maybe someone with a 1-1.5T AgroTK
or CFG can measure the max charge current for us?
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #145
I will check it with my DC clamp on once the weather breaks. I did read somewhere that the B&S alternator for these is max 9 amps (3600rpm). 9a at 12vDC is 108 watts. That is why I only went with 1-80w fan in my unit.
Edit: Well I was able to take a reading just a minute ago. it came out to ~4.5a going into the battery after a cold start nothing else running during test (except hour meter). This would seem to indicate a 5a alternator which is one of the possibilities for this model B&S. If so running even the 80w fan will deplete the battery over time. Good thing I am routinely plugging it into a 1.75a battery charger/maintainer.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #146
All of the baby-X from China that I have looked at under $10000, have either or, not both. I cannot find any info on the AGT website that tells what the unit is set up with. When I saw the pic of my machine before I bought it, I was happy to see the hyd cooler and fan. Then came the disappointment when the machine was delivered and I discovered the hyd filter wasnt installed on my machine. :confused: :oops:
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #147
I really hope we have more charge than that.. I was hoping for the 10 amps I understood the Briggs to have. I dont think there is any other way to cool these hot blooded little diggers than electric fans.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #148
I am disappointed in you, Rusty! Didn't you read and look at the flywheel fan ducting I did? It is very effective, and not hard to add.
3A and 10A alternators are the options offered on the B&S product page. I suspect the 10A option is a multi-coil stator, and would add significantly to costs. The Honda GX340/390s I have opened up have one or 2 separate coils, which look like bolt-on mods to Chondas that only have one coil (like my Duromax 420).
I measure my charge current at less than one Amp, so I added a wimpy 500mA electric fan to help out.
   / Agrotk excavators: Does anyone have one? Opinions/comments/critiques? #149
Calm down :) Ha-ha I am your biggest fan.. I read your thread more than anything on here, the ductwork is on my list to do and will be simple enough. I definitely pay attention to your advice. I just don't get to do everything I want as soon as I want. I would be a fool to not use all the good tips you toss at me. Also, I noticed the voltage regulator on the briggs is much smaller than that on a Honda GX390 I have on a SXS. its rated for 20 amps.
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
New/Unused Electric Horseless Carriage (A57453)
New/Unused...
