Air Compressor Oil
/ Air Compressor Oil
Thanks Hazmat
I've got an induction motor.
My first set of measurements show it starts at 34 amps and drops to 12.5 amps within a second then as the tank pressure builds the amps rise to 14.5. This is with the factory 30 wt mineral oil. I plan on getting a few more measurements with the mineral oil then switching to synthetic for a comparison.
/ Air Compressor Oil #22
I have an Emglo that I have been heavily abusing for 10 years.
I use Valvoline racing formula.
Good enough for Indy, it's good enough for my compressor.
Must be very good because this guy has been HEAVILY used and still runs like a champ with the same oil.
/ Air Compressor Oil #23
What is the CFM required for the job? A roofer's compressor that is commercial grade but limited to about 5 CFM will work for most applications, and is portable.
The requirements go endless for commercial users, however, I always go as heavy as my pocketbook can afford as a homeowner because I never like buying industrial tooling more than once.
Buster57
Have you had any problems with the discharge valves breaking or carboning-up?
I'm curious because all the compressor companies I've looked at warned against detergented oil, such as Valvoline, because it deposits carbon in the compressor.
However, out in the real world many people like yourself use their favorite motor oil with no problems noted.
Could it be the compressor companies wanting to sell me $0.79 oil at $7.99?
/ Air Compressor Oil #25
I bought a 7 HP 60 gallon (12.1 SCFM @ 40 psi and 9.7 @ 90) Porter-Cable at Lowes for $379.
The manual says not to use Multi-Viscosity motors oils, they leave carbon deposits.
Use SAE-20 API CG/CD heavy duty motor oil. Under extreme winter conditions, use SAE-10 weight.
Billy
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
Kubota M4700 (A60462)
