Alien Invasion - I want my pond back !
   / Alien Invasion - I want my pond back ! #51
I did a bunch of science fair experiments with siphons when I was a kid. I still use siphons about every other week to drain our pool cover of rainwater. Also transferring gasoline from a vehicle to a can. Simplest method is as I mentioned above. Only requires one valve if the pipe is larger than your palm. No valve if you can cover the pipe with your palm. Watch this video. Its the closest I can find to what I do. Siphoning begins at 30 seconds. Guy starts 20 siphons in a couple minutes. No pumps. No valves. Don't over-complicate things. ;)
   / Alien Invasion - I want my pond back ! #52
Here's another one. Guy just uses his thumb. Open it when shoving the pipe into the water. Cover it when drawing it out. Open in. Cover out. Your thumb is the check valve. Works great for gasoline, too. Exact same principle with larger pipes.
https://www.youtube.com/watch?v=2j1FoLDcwZk
   / Alien Invasion - I want my pond back ! #53
Moss, What is the longest pipe that method would work with?
   / Alien Invasion - I want my pond back ! #54
   / Alien Invasion - I want my pond back ! #55
Length isn't an issue for the most part. Lift height is, however, an issue. It has something to do with the barometric pressure of the liquid and gas in the liquid. For water, its something like 30'. Any more than that, and the air bubbles will be sucked out of the water, creating an air pocket at the highest point in the siphon and stopping it or something like that. It's been a while. Anyhow, there's a whole massive formula to figure it out.
Siphon - Wikipedia, the free encyclopedia
   / Alien Invasion - I want my pond back ! #58
I think his point is obvious. Can you lift and work with 200' of 2" like in that short video? No, of course not. Thus it will require some other method of priming. Like the pump noted by the OP. But yes, this is an interesting TBN drama... Subscribed!
   / Alien Invasion - I want my pond back ! #59
I actually turned OFF the TV to read this!:eek: I'm an avid multi tasker... and I was going to go to bed early, 'cause I'm whipped tired from tractoring all day, but here I am, and no closer to who the aliens are. Is there a DVD or something to skip a chapter ahead?
   / Alien Invasion - I want my pond back ! #60
I'd loop the hose half way down the hill and keep both open ends by the pond. Then I'd just work a short loop into the pond, dipping it full and lifting, dipping and lifting, until the hose had enough water to get over the hump. Then I'd plop one end into the pond and drag the empty half down the hill. It will fill on its own by the time you get the end extended. Piece of cake! :thumbsup:
1996 Sunflower 1543-38 Folding Disk (A57024)
1996 Sunflower...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
2018 John Deere 1653 (A55314)
2018 John Deere...
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
