All in the same ditch/trench
   / All in the same ditch/trench #21
You need to keep the power and phone separate. 12" is the EIA/TIA recommended separation but you can probably get away with 6" and not have issue. The reason for this is to mitigate EMI (Electro Magnetic Interference). This can create a buzz sound on your phones. Never seen a phone line installed with power in a conduit so I'm not certain if this is a code issue, just not common practice. For this short distance I would install a 3/4" conduit and basic CAT3 unless you have any near future desire for a data connection. A pull string installed with this cable is wise just in case you want to add any other LV cabling (i.e. coax, control wiring, etc.) Fish tapes are nice but not necessary for a person only fishing a conduit on occasion. Any stiff wire like Romex or RG6 coax will suffice for this type of distance. Regular dish soap assists if there is any friction issue with fishing the line. Keep number of 90 deg bends to a limit of no more than 3 without a pull box.
   / All in the same ditch/trench #22
I have to agree with the cat 5 wire. I have allot of it left over runs and use it all the time for phone connections, doubling up the conductors to make the two for the phone, Of course this could also be used for the comp in the future.
   / All in the same ditch/trench #23
LB started this thread two years ago. I wonder if he might already have the lines run?:D
Mark
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2023 BOBCAT E88 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E88...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
