Amsoil
   / Amsoil #31
JBM - your questions are all valid ones. I'd use either 5w30 Diesel or the 10w30 'Turbo' in them. All the Amsoil diesel oils I've seen also meet every gasoline spec in common use. Let me know what Amsoil says, if you call them.
Mark
   / Amsoil #32
I swear, Paul, you kill me! :) (Sorry, I still have to learn those little facey things!
   / Amsoil #33
Billc, Click on the "FAQ" and read the "Can I use HTML in my posts?" section about the "Markup" and you, too, can make funny faces./w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif/w3tcompact/icons/laugh.gif
Bird
   / Amsoil #34
Thanks Bird.
   / Amsoil #35
PaulB, now how can you pick on a Dodge diesel. Are you still not getting enough sleep? I mean it has THE engine! This comes from the voice of experience. My last diesel pick-up was a '85 GMC. All I'll say about that piece of crap is that at about 70,000 miles the engine blew. I now have the advange of having a Ford 250 diesel and a Dodge 3500 diesel. What a difference in engines, Paul. Just the other day I taped both engines. I came in and listened to that sweet sound of the Cummins, and then to that whimpy spattering noise the Powerstroke makes. Then I decided to slow the tape down and listen to the two engines. God, when you listed to the tape of the Cummins slowed down by 50% you hear "BHA DA DA DA DA DA DA DA..." But when you hear the Powerstroke tape slowed down the same amount you hear "far-fet-nu-gan, far-fet-nu-gan, far-fet-nu-gan" (This is not meant as a cut to Mark and his Volkswaggon)
   / Amsoil #36
BillC - Good one! /w3tcompact/icons/smile.gif
But did you know that if you play the Powerstroke tape backwards, you get "When I grow up I want to be a Cummins"??? /w3tcompact/icons/wink.gif
Mark
   / Amsoil #37
Bill - we all know about the mid 80's GM disel experiment - everybody makes mistakes now and again. I am sure the Cummins is a great motor, and I am sure it will outlast the crap of a truck that it sits in too! Now, a Suburban with a Cummins - that would be sweet.
   / Amsoil
Where's the "off-topic" police when you really need them.
JB
   / Amsoil
MarkC - here's what the Amsoil tech guy said: Any Amsoil API diesel rated oil can be used in a gas engine because the the criteria for being rated a diesel oil is more stringent than for a gas-rated oil. As for viscosity, the 15W40 Diesel oil is close enough to the 10W-30, especially here in Florida where the air temperature rarely falls below 30F, that it would be fine for use in my gas engine Jeeps. Also found out that viscosity is measured in "centistokes" (not sure of spelling) at 212F(100C), and that it is a measure of resistance to flow in square centimeters per second through a specified diameter orifice.
In addition, he says that the same Amsoil Diesel oil is fine for use in the small 4 cycle engines (B&S, Tecumsuh, etc.)I use to run an irrigation pump and an AC generator. Sounds like I can reduce the number of containers on on my lubricant storage shelves.
JB
   / Amsoil #40
PaulB - I heard about a guy who tried to put a Cummins engine in a Suburban but he couldn't keep oil in it - it kept throwing up. He ended up putting it back in a Dodge and it was fine. /w3tcompact/icons/wink.gif
Mark
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
Killbros 260 Seed Conveyor (A55301)
Killbros 260 Seed...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
