another 4300 design flaw!
   / another 4300 design flaw! #11
Perhaps he is talking about part 20 here:
exactly right Cocre. the plug just pushes in, with some sealant. there is no stop to 'bottom it out' on
i understand that it is not a bulldozer, and it is not a tank, but it IS a tractor. i should be able to drive over a pile of dirt (straddle it) and not experience a potentially catastrophic front end leak.
it would have relatively simple to design the final drive housing with a shoulder that the plug would contact, so then it could withstand SOME pressure on it. as it is, it can just push in until it hits the kingpin with very little pressure. better yet, it would have been simple to make a solid cap to fit over it.
now, i have not studied it closely yet. it looks like it just got pushed in, but it could be crushed. if it's crushed, that's ALMOST understandable. but they could have still put a piece of 4" round steel over the bottom.
i plan to make some guards for it, will post pics if i get it to come out decent!
this 4300 is cursed!
got the new cap - manual calls it the "final drive housing spindle cap"...got the old one out pretty easy (not crushed, just pushed in), dry fit the new one, no problem, applied sealant, went to fit it back in, and i can't get the stupid thing to go in correctly. granted, if i had a 3" diameter seal driver, it would have been easier, but the last one i did went in real easy. hopefully it seals.
the one i removed is the same style as the new one, but the one on the other side is different. looks heavier and seems to seat differently. apparently the replacement caps aren't the same as the factory ones. the one that got pushed in is the same side that i took apart to fix a seal, and it looked as if it had been apart before then, so they must have put that new style cap on then.
then, i find some metal filings in the oil i drained from that one final drive. already drained it 2x w/o finding any, so not sure where that is now coming from. drained the rest of the oil, and walked out to look for something...when i come back, oil all over the floor. my drain pain had a crack 1/2 down!
nothing went easy except buying the new cap and removing the old one.
Does the local JD dealer have an exorcist on staff? :D
i'll check JD parts!
i'll put some oil in tomorrow and see if she seals. it shouldn't, but with the way this simple job went, it won't surprise me to see it drip.
there is not as much space, vertically, on the final drive housing as i thought...a cap is going to be a challenge. my idea needed more room than i have.
   / another 4300 design flaw! #17
So JD has changed the part and that elicits more complaints. And whose fault is it that you don't have the proper seal & bushing driver? Deere & Kubota both used that design on thousands of tractors, I have never seen one of those caps fail. If you can get the rest of these guys to believe that a pile of dirt wrecked it, so be it. I don't.
   / another 4300 design flaw! #18
Too many of you men are bashing defed... He bought a tractor he's not used to and maybe being a bit cautious. Plus, being a used 4300, it's likely got a few flaws here and there. I saw the pictures of it (on Machinefinder.com) before he bought it. Decent tractor, but not a jewel.
However, the 4300 and such, although fine tractors (one of Deere's best efforts, IMHO), it's not a farm tractor. My guess is the market was local landscapers, rental companies and "gentlemen farmers" with little "in the woods" work expected. Hence, the exposed turn signals and other such things. One long time criticism was the vunerable underside (I read about this when those tractors were current product) which lead to a number of ripped hydraulic hoses, wiring and eventually led to the underamor kit to protect the "belly of the beast".
   / another 4300 design flaw! #19
Nice post Roy, too many of us buy something, use it as it was not intended and are disappointed. Some of us modify to suit our needs and others cuss the engineers. Those guys have restrictions too and probably shake their heads at what they are forced to produce. After all we all are human..................
never said it was anyone's fault that i had trouble replacing the cap, except for the fact that it shouldn't be so easy to damage and shouldn't have needed to do it in the 1st place. you can believe what you want, but the simple physics of the matter is, if anything comes in contact w/ the cap, it CAN get pushed in. even driving on an uneven pile where the wheel is at the low end and the pile tapers upward under the tractor. and to purposely put an open hole w/ a friction cap, pointing straight down, exposed to potential damage, seems like a flaw....which was the original intent of the whole post.
brush hogging, lots of limbs/stubs on the ground. i can see one hitting the cap and pushing it up. the original cap was not damaged, just got pushed up and unseated.
Year: 2017 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 25,859 Plate: Body Type: 2 (A55788)
Year: 2017 Make...
2842 (A54757)
2842 (A54757)
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A55787)
2025 Single...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
UNUSED FUTURE SE61 - 61" HYD BROOM (A54757)
UNUSED FUTURE SE61...
