Another JD3320 vs. NHTC33DA question
   / Another JD3320 vs. NHTC33DA question #11
<font color="red"> If the tractor is too big for the property, is the issue of possible damage to the lawn or equipment, or is the issue...The dumbass paid wayyyy too much for what he needed? I do appreciate any and all advice regarding this as I've never even considered that I was buying too large.
</font>
I suppose I will remain the lone voice that you are buying too big. But here goes my logic.
Too large issues:
* Can't fit into some places! - This is not an issue if your land is treeless, fenceless, and devoid of lots of landscaping. Will become an issue if you use the tractor to plant things!
* Heavier - Don't think of pulling it out of the garage after a rain (maybe for several days).
* Too tall to fit under the small trees, have to fold the ROPS to get into the garage - no explaination needed.
* rutting the lawn (even in dry weather on dry soil) - on a small property like 3 acres, you will be running the tractor over the same areas and compacting the soil, you'll find that you will eventually rut the yard if you keep going over the same areas (like through a gate) because you can't take other paths. With larger property this is a non issue.
* sure it costs more, but if you want to save money you could find a bargain brand machine instead, I am all for you spending $22K, but I really think you will find you end up buying another small tractor or push mower or rider in the future because the larger machine is too cumbersome on a small property. I'm all for you spending your money but I don't see that you need to throw it away.
Just my experiences here, but I have a hilly 10 acres with about 25% woods, 35% farm field, and 40% of the property has trees spaced 15' to 50' apart with some rare open areas. I use a B2910 and a TC24 and find the B2910 won't fit into places the TC24 will fit into. There are times I really wish I even had a smaller machine than the TC24. We have put in many landscaping beds over the past decade, and a couple of fences. The TC, small as it is, can't even mow in some of those areas and I have to pull out the Ventrac for those areas. I'll admit in the farm field (which is 3+ acres), the TC24 seems pretty small, but the B2910 doesn't, and that is smaller than either tractor you are considering. In fact, there is really no reason to even have the B2910 since buying the smaller, but still very capable TC24, and I have over 3 time the amount of property you have. Now the B2910 does come up to the industrial park for snow removal duties every winter so it is in no fear of going unused. But I think you will find that on 3 acres you will be using far too much machine and will eventually end up push mowing or getting a small rider for around your house, fences, walls, and landscaping. You said your main jobs included MOWING the lawn, honestly I feel you are really going to regret a large tractor on a small piece of property. Just my 2 bits. Others obviously disagree.
Why don't you RENT a tractor for a few days, drive it around the property, try to mow up against your wife's prize roses, imagine planting more trees, flowers, etc because that is what most new homeowners do, and the see if you will end up with a cumbersome beast that is too large to efficiently use.
EDIT :: I went to the New Holland Product Counselor and filled in criteria based on what I understand your property to be. Mowing 3 to 10 acres, material moving, gardeing at <2 acres, snow removal at <1/4 mile. The LARGEST tractor they recommend is very similar to the JD 4115. The recommend 3 of the very small Sub-CUT TZ series machines as well as the smallest 2 versions of the TC class machines, the TC23 and the TC26.
New Holland product councelor
   / Another JD3320 vs. NHTC33DA question #12
<font color="green"> I'll play along... </font> /forums/images/graemlins/smile.gif
Too large issues:
<font color="green">Not an issue. A 60" deck is a 60" deck. </font>
* Heavier - Don't think of pulling it out of the garage after a rain (maybe for several days). <font color="green">Only been a problem once in the early spring, even with loaded rear tires. </font>
* Too tall to fit under the small trees, have to fold the ROPS to get into the garage - no explaination needed. <font color="green"> ROPS is folded all the time anyway. For a while the top section was even off it and laying in the barn. </font>
* rutting the lawn (even in dry weather on dry soil) - on a small property like 3 acres, you will be running the tractor over the same areas and compacting the soil, you'll find that you will eventually rut the yard if you keep going over the same areas (like through a gate) because you can't take other paths. <font color="green">I can see rutting dry soil with a big tractor, something like a JD 7810, 8020, etc., but a 3320? Hasn't happened to me yet, even with the aforementioned loaded rear tires. </font>
Four acres of yard here, surrounded by fields (wheat & beans) and am VERY thankful for a mid-sized CUT for lawn and snow removal. Thankful I didn't go any smaller.
   / Another JD3320 vs. NHTC33DA question #13
dmp437, I have to say I love your 4310, but I stand by everything I wrote as accurate for a small property. I won't pretend that some people can't run 50 or 60 hp tractors on 3 acres, I am sure they can. I think it is pretty foolish and inefficient.
But as for picking apart my post, I can cite some other examples, real life, on my property. Every one of my gates is a fairly narrow gate, just large enough to get equipment through. Every one has ruts from traffic. You say you haven't had that problem of dry rutting, I have proof of it.
As for the ROPS, you took yours off or you keep it folded, that is a personal choice you make, but as I have a lovely family and as I understand how dangerous these toys are that we all play with, I leave my ROPS on and wear my seatbelt because I believe my family will miss me.
As for the thought about a 60" deck being equal to any other 60" deck that is simply wrong. Why does a ZTR mow so fast? It is not because the deck is larger than a tractor deck. It is not because it has a higher ground speed than a tractor. It is because it turns tighter. So take a big tractor and a small tractor, equal size decks, the smaller tractor will beat the larger mower every time due to the increase in speed around the landscaping, turns and other obsticals. On my upper yard area I would gladly "race" your 32hp midsize 4310 with my 24hp small frame TC24, or better yet, with a little JD2210 or a TZ class NH, because those will mow faster than my TC24 and your 4310 won't even turn in between some of the areas I mow around even if you drop your FEL and use a 60" mower deck.
Now I'm not hear to agrue with anyone, so I'm done for this thread. I simply am offering a common sense analysis, even if it is against the grain of virutally everyone else here.
Though size is now a consideration to ponder, how do they both compare in regards to quality and reliability? Is there an equal showing but with two set of groupies...ie., Ford/Chevy fanatics? If there's not a difference, I'm forced to go NH with it's Penn State Blue. On the surface, both seem to offer equal power, options and gadgets.
   / Another JD3320 vs. NHTC33DA question #16
As far as quality and reliability, I would rate (in alphabetical order to keep it fair /forums/images/graemlins/smile.gif ) Deere, Kubota, and New Holland at the top of the heap. This takes into account not just initail quality and reliability but also a strong, established dealer network. There will be occasional issues but that is where having a good dealer comes into play.
   / Another JD3320 vs. NHTC33DA question #17
</font><font color="blue" class="small">( I suppose I will remain the lone voice that you are buying too big. But here goes my logic. )</font> Nah. I second your opinion.
I bought based on the needs of the tractor at the time. I based it on what I *knew* I was going to be doing. Well, after I was done doing it, I could have downsized the tractor accordingly. Heck, I probably could have gotten by with a smaller class tractor to begin with.
So, my advice is, think what your going to be *really* using it for in a year or two. Brush-cutting and mowing don't count, because you can get by with something else for that lot size if your interested in lawn care.
-Mike Z. /forums/images/graemlins/grin.gif
   / Another JD3320 vs. NHTC33DA question #18
While I'm personally a green guy I think there are alot of really fine tractors on the market. You can't go wrong with any one of the big three and the new Farmall tractors look pretty good to. As to the size issue just buy what you'll enjoy. You can always mow the yard in different directions/arrerate or whatever to keep the ruts at a minimum. Nobody really needs a corvette or a Hummer but it isn't always about need. Some times its about want and if you can afford it I say why not? So it looks factory fresh and you only have a couple of hundred hours on it after five years. I bet you'll have a few thousand dollars worth of satisfaction and 200 hours worth of good memories. Just go for it.
   / Another JD3320 vs. NHTC33DA question #19
I have the 33DA with SS on 7.5 acres... plus horses... and think its great. For you... too much. If you are going with a tractor that size, go with the NH with the SS... tighter turning and auto 4wd. You really can live with much less... spend more on keeping up with the Johnsons elsewhere.
Thanks Rich
   / Another JD3320 vs. NHTC33DA question #20
I agree with everything Bob has recommended to you. I own a 3320 and use it on 10 acres basically as a full size tractor. We cut the 2 1/2 acre lawn with many trees and landscaped areas, with a 16 horse hydro w/ 48"deck. Its much more maneuverable in the tight spaces and around all the trees. I'm planning to buy a 60" ZTR mower to replace the 16 hp lawn tractor in a few years. The sub compacts are better suited for mowing, but can still do some of the tougher chores as well. If you want to outdo the neighbors get a Deere. /forums/images/graemlins/smirk.gif Best of luck to you in whatever you choose.
1995 Cat 963B Track Loader (RIDE AND DRIVE) (NICE) (A50775)
1995 Cat 963B...
2011 E35M Mini Excavator (RIDE AND DRIVE) (A50775)
2011 E35M Mini...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
Red Cedar Wood Rocking Bench Seat (A55758)
Red Cedar Wood...
Decorative Metal Butterflies (A55758)
Decorative Metal...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
